hey guys im new here just wondaring where i would be able to get some sau stickers
any help would be much appreciated thenks :P
Hey mate, welcome to SAU! The SAU:SA chapter dyno day is on August 15th, there will be stickers around on the day!
anyone know if Turbo Tune are even open today ?
ive called 28 times since 2pm and its constantly engaged...
there have been people standing out the front trying to contact them....people going into bridgestone across the road asking if they knew where they were....no one knows where they are...
really random
also...if someone comes across some cheap nissan bits.....give they boys at Grand auto wreckers a call on 83826066...they got broken into (again) over the weekend....not 100% sure what they flogged as when i rang, the police were there and Anthony didnt have time to chat
really random
ok now im actually starting to freak out
Your car is still in there isn't it?
Sounds suss. :P
yer it is, and im thinking of the worst thing that can happen and im not too chilled right now, specially because i cant get there anytime soon as i dont have a car...
I hear Grand Auto got broken into recently. Maybe TT got hit too and they're locked up until they can assess what from what? Just a stab. Any cops on site?
Is anyone getting around the back of that place?
:P
:P
cheers krishy :P
I can only image as to what your feeling right now mate.....28 times you call....phone engaged....people standing at the front trying to contact them.....doesnt add up or sound too good....and you have had so much bad luck with that car mate.....for your sake mate hope this is the last of the bad luck....
Cant wait to see you out and about in the orange beast again
Good luck
Good luck
cheers man, im not at ease right now...
im headed there now, ill let you all know what the out come is
i can see the headline now
"Three dead in import workshop murder"
"Mitchell of Adelaide has murdered three trespassers at an Adelaide import performance workshop, Turbo Tune, at 4:30 yesterday. The three were seen attempting to steal an orange R33."
spoke to Michael down there , they got robbed aswell.
they went through everyone's car including mine and my whole dash was pulled apart.
couldn't go inspect as crime scene investigation hadn't arrived to go over the workshop.
when it rains it pours
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
