could buy parts yourself.
gates timing belt kit with cnc bearing kit $300 roughly
full synthetic oil and oil filter, plus radiator concentrate $100
rb water pump under $100 oil pump $150 or spend more now perhaps rb26 for $300ish, tomei for a grand lol
full nissan gasket kit $200
add in labour and thats the job.
Hi guys,
Snice i bought my R33 about a year ago, ive had all my servicing done by synergy, now i know there a bit over priced but i never had any trouble. Now my car has just hit the big 100,000 so its time for the major sevice.
Now synergy said it would be 900 to a grand depending on a couple of things(which i thought was a bit much!)
Now i heard a few good things about Pitlane Proformance, so my question is........does anyone from Pitlane post on this forum and could give me a rough quote??
Or
Anyone who goes to pitlane and is really happy with them???
Rule #4. Synergy fails... for importing and mechanics.
Don't bother with them. over priced, bad rep, etc.
Take the car to a decent mechanic.
Any suggestions Cronic???
By the sounds of it im still gonna be looking around the grand mark.
Cheers guys!
Cheers guys!
What area do you live/work in? Some things to consider if you have a low bodykit etc (such as steep driveways). Also, check that they have insurance, so if the building burns down or your car is raided its covered.
Well i work in Hilton(City of west Torrens) and i live in Hillbank, close to Elizabeth........
And my cars lowish(if thats a word) but i can get up driveways....just :D
it's my daily drive so near somewhere near work would be better.
I have the same problem. If they're not open on weekends, I gotta take a day off work or organise a ride for drop off and pick up. A workshop like Boostworx or Southern HiTech in the city would be awesome.
Istead of doing work i called around and got some prices.
Smooth Garage- $1100 approx.
Boostworx- $1350 but comes with a dyno tune :)
Pitlane want around $1000
There ya go Damo,, did it all for ya :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
