Just got back from a run guys,
Great weather for it car loved it. I need skinnier tyres or rolled guards now that it sits a bit lower,
I think I'll go with skinnier tyres and try that out as I dont want to roll and molester my guards ahaha.
200's pretty much done. just gotta refit the front bar and the cold side cooler pipe and fit the fuel pump. oil cooler was pretty lol, ended up using 4 fittings just on the return line so the hose could clear the rad support and the fmic.
spoiler looks pretty rad. as does my new 'silvia' badge on the boot.
so luke/wayne, hills runs will be in order soon. might bring back the midweek runs.
would post pics. but 3mb photos + capped internet speed = 5 day uploads.
Edited by scandyflick
joisus. GTR pumps are fair beastly compared to the 200's stocker...
and now im off to collect a free carton of beer from work. ;)
Should had gave me a msg on Facebook! I would had come out!
check this thing out and their whole website. Want a 34R NUR with 18km on it?
http://www.zeleperformance.com/vehicle/r34...registered.html
Some very nice cars there ;)
http://www.zeleperformance.com/vehicle/r34...lack-pearl.html
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
