pretty sure your going to need gtr headlights dude
see im not that dumb i was right
you may get away with headlight spacers to bring the original one's forward, i know that's what you can do with R33 > GTR conversion
edit
oh bunny :P
yeah i do to and im fine now a little hurt but fine i acually see the funny side of things a bit anyway. drop kick is a understatment
Kell, before I met Tracy, I dated a 25yo for about 2 months. We got along real well, or so I thought. She started going cold ... like had no time to see me. I go over there and demand an explanation, she hands me a note. The contents were unclear and bs anyway, so I just left. If its no good, its no good. I had my suspicion she deveoped an interest in someone else. Im not stupid. I told her my theory and at first she didn't deny it ... guess she didnt think I was smart enough to catch on quick.
Anyways, goes to show guys get the screw around too ... good thing is I have Tracy now :P
well oh well ill just cruise with locky if someone comes along then good and if they don't then ok its really to hard to find someone that doesn't care about the car i drive or that i have a son so i officially give up
so yeah , RB25DET wont be happening for a few months to a few years etc etc ,
gonna work the crap out of my RB25DE for now
suggestions for getting some more power out of my N/A ?
im thinkin something like
Port and polish
oversized valves
cams
gasket ?
y bother!!???
spend it on the 25det u fool lol.....
worst thing i did was spend money on the 20!
True. By the time you work the DE, you could have fit in a DET and sold the DE and make some money back!
hahaha i gave up a while ago!
we will get to gether adrain i mean we already slept together camping hahaha
Didn't the girls give up first :yes:
Kell, thats when things usually happen ... when you're not looking. :P
nope im over it
Port and polish
oversized valves
cams
gasket ?
dont bother. huge amounts of coin for very little tangible difference. like i said on that cruise the other week up in lofty, either harden and get a DET, or strap a vortech (or even a commo v6 roots type) and a W2A intercooler to the DE with a flashed ecu.
Edited by scandyflick
yeah i don't know man , just gotta wait n see how my financial situation pans out in the coming months i guess
Ok this may just be me, but is anyone else's post times going all over the shop?
Like just then on the main page it said the last post in this thread was at 1:03 (ie hasn't updated to daylight savings time) but when I go into the thread the same post reads as being posted at 2:03 (the correct daylight savings time)
Like I said, may just be me absolutely tripping balls.
yet you talk of
...Port and polish
oversized valves
cams
gasket ?
there all not cheap, hang onto your coin save save save and before you know it throw a RS4 engine in it and you will be ever so please you waited and not wasted 2.5k on worthless mods to make a make of 40-50kw
+1
Guest
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
