I recently bought this turbo for a screaming deal with the thought that I can sell it for more or install it on my RB20 down the road. I was told that it was from a R34 Neo RB25DET with only 15,000 miles on it.
I need to determine whether or not it is a Neo turbo or just a R33 one.
The intake housing has 45V2 stamped on it. As far as I have read that narrows it down to either RB25DET or VG30DET.
The Exhaust housing has an OP6 or 0P6 on it.
The exhaust side measures about 48mm near the flange.
Edited by cpt_impossible
I have tried searching this forum for the info since the States don't have a lot on the RB engines, but I keep getting different info depending on what thread I read. Some threads indicate that its R33, some Neo, some Leopard. A definitive answer would be greatly appreciated.
Thanks
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
