Selling my CUSCO rollcage that came out of R32 2dr. Cage is fully padded, so practicly new under all that padding. Comes with all bolts, nuts, and plates.
This is a pic of what it looks like....
Price: $800 ono, can also post interstate
Located in Melbourne
Edited by FOBS15
https://www.sau.com.au/forums/topic/188682-sold-please-delete/
