GTR original spoiler for sale - Make an offer.
r33 Standard springs - $120 o.n.o
Standard series 1 r33 front bar - Make an offer
Standard series 1 r33 front indicator lights - Make an offer
r33 S1 grile - $50 o.n.o
I dont need any parts they all must go, so the highest bid will get them.
spoiler is silver in colour and has one minor scratch, springs are in real good condition.
Cheers
Luke
https://www.sau.com.au/forums/topic/18869-r33-parts-4-sale/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
