What to do what to do?!?!?!
With the right tuning 300kw atw is easily obtainable with std internals. Gone are the days of any engine that is running a moderate amount of boost needing forged pistons. Don't get me wrong, forged pistons are great, but a lot of the time not necessary for the application. Money better spent in other areas.
One of our technicans is running a 4AG 1.6L engine in his MR2 which has std internals (2nd hand at that) and is pumping out over 240kw atw + 11.7 sec 1/4s.
look there is no answer to the question how long will my internals last at 300rkwk.. or how hard can they go before they go boom..
its all dependant on luck (how strong the engine is).. 2 identical engines run side by side with 300rwkw.. 1 will go boom after 5,000km.. the other after 50,000km... thats just how things seem to work with cars.. im sorry but there is no magical number that once u hit it everything goes boom..
your definately right. every engine condition is different. 300rwkw is a pretty extreme output for a std bottom end but in a skylines case, can be done (given that the engine is in sound condition). incorrect tuning ie: running air fuel mixtures too lean to achieve higher power levels can have a lot to do with engines going bang.
all i was trying to say is that there is a lot of high output and reliable engines around out there that retain a std bottom end.
Guest Mr IAI1124
I am looking more towards pulling the engine out and just stripping it back mostly myself and then just send it over to my mecho (not one that busted it!) and have it rebuilt with forged pistons, bigger turbo new ecu etc spend say maybe max 10 grand but hopefully it will end up putting out more power and have more reliability. Anyone tried a bolt on TD06???
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
