hey people......
Well i have A stock R33 with these basic mods.
FMIC,
3inch turbo back,
bosted to 12psi on the switch, 7 without.
Pod filter with UAS air box
Turbo smart BOV type 2
Extreme button clutch
S AFC = coming soon
Now i want to advance Timing what do you guys reckon it should be set to
and what have set yours too?
thank you in advanced
https://www.sau.com.au/forums/topic/188905-advanced-timing/
ive got a r34 and the timing is super advanced .. wtf its like that i dont no .. pulls like a bull on roids tho :) (
yes indeed ............mine is a bull on creatine....
i want a bull on roids
https://www.sau.com.au/forums/topic/188905-advanced-timing/#findComment-3405850
Base timing should be left at the factory 15degrees and a tune should then be done to alter any timing settings under full load...
so practically just wait for the SAFC then start talking
https://www.sau.com.au/forums/topic/188905-advanced-timing/#findComment-3405882
i'm not sure how an safc is going to what you want it to do, unless they have changed and now they timing but as far as i knew you could only change air flow meter signal, so to change timing you would be changing base timing anyway.
https://www.sau.com.au/forums/topic/188905-advanced-timing/#findComment-3406315
+1. safc cant change timing, only an air flow signal bender.
https://www.sau.com.au/forums/topic/188905-advanced-timing/#findComment-3407551
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
