*sigh*.... some people jus dont get it... when you go have an EPA test at McCloud, they do an EMMISIONS TEST there and then! they messsure the carbon monoxide (correct me if im wrong on the what they test for) levels in parts per million (PPM) and deem if it passes or not....
now to go a bit further in detials for those who are extra thick:
i am extra thick, well thats what i been told anyways ;)
i am extra thick, well thats what i been told anyways >_<
you are very very lucky to pass a epa test with mods, you might pass the noise test and emission test how are you going to pass the engine bay examiantion, the EPA dudes are all mechaines. they might let you off if you just have high flow injectors but im pretty sure if you had GT3076r, z32 AFM, 740cc injectors, 4inch intake pipe with a pod, intercooler and many other things they will just tell you to get f**ked lol :)
you are very very lucky to pass a epa test with mods, you might pass the noise test and emission test how are you going to pass the engine bay examiantion, the EPA dudes are all mechaines. they might let you off if you just have high flow injectors but im pretty sure if you had GT3076r, z32 AFM, 740cc injectors, 4inch intake pipe with a pod, intercooler and many other things they will just tell you to get f**ked lol >_<
i think you replied to the wrong person, i never said i passed with mods...
skywhine has been arguing that point :)
lets say purely for arguments sake that a standard RB25DET running on 7 pounds produces 100PPM carbon monoxide standard on a stock standard shit fuel ready 16:1 AFR map.
now that safe level u have to stay under is 100PPM, if u have a bigger turbo, bigger injectors, plenium even more boost as long as u stay under the 100ppm ur safe, now the way to do this is to have your car custom tuned, when cars are tuned they make more power and use less petrol because they run better AFR's (and a few other things; spark timing etc), instead of running a 16:1 shit fuel ready bomb tune, they will adjust so u run something a bit closer to 14.7:1 which is the optimum level... now since you now run a leaner AFR the amount of carbon u spit out the exhaust will be less, hence how people with half a brain pass modified cars....
Why do people who have no experience taking a skyline or turbo'ed import down to Mcleod insist on giving advice ;)
SKYHY....I can assure you because I have been through this very process as well as knowing ADR's and Vicroads/EPA guidelines on car mods like the back of my hand, that they don't just do an emissions test. First up they have a visual inspection of things like your ecu, turbo, intercoolers, emissions gear like afm/carbon canisters etc, exhaust system, fuel rail/injectors, air box/pod, boost control and fuel pressure reg. You MIGHT be able to get through with some aftermarket inj and stuff because some of them look stock....the same with OEM style turbos. However I can assure you they know what a PFC looks like and they even check whether your std computer has been opened and hence chipped. Assuming you get through that they then do an emissions check and then finally take you to the open area for a noise test.
As for the emissions level, they will pass you if you are over as long as all the aforementioned stock gear is there...why.....because as a car ages it produces more emissions than it did when it was new because things like the cats ability to absorb emissions reduces over time and engines get 'dirtier' as they age. However if you are over by a big margin they might start asking questions.
Basically read through the EPA sticky thread and listen to the advise given by people like Ash (R31Nismoid) as he knows the rules inside and out :rofl:
lol there job is not 2 check for modifications...
they are not the "bigger turbo police" or the "injector inspectors"
they are the EPA - Environmental Protection Agency
there job is to protect the environment, by making making sure u aint making either noise polution or emmisions pollution... if your car is modified and still complies it will pass, put a standard air box n zorst on, make sure it aint running rich and put the catch can in the shed for a bit...
and my chipped ECU was fine, was lying on the passenger floor at the time, wid a big shiny "custom chipped by Electronic Automotive sticker on it" and i also had 1 on the back window aswell as a sticker with "James Race Engines". and i had extra wires hanging out the ECU for extra knock sensors... so please stop with the shit that u cant have a modified this and that... you dont know what your on about and ur filling peoples heads with crap....
take my old car for instance... big cam V8 wid high compression, bigger injectors, bigger throttle body etc... how is that supposed 2 pass EPA with out a remapped computer? should i strip the engine down n return it 2 standard? ...yea right. would have been less effort to sell the car, think about it, there would be 200 cars a week in the paper wit no rego for sale because of not passing EPA.... it jus doesnt make sense... and thing that dont make sense usually just aint true - Judge Judy :)
skwhine you have no idea, its as simple as that really. If you dont know what your talking about, pipe down.
"The EPA"
1. Their job is to check for Modifications that surround the emissions. That includes injectors/ECU's/O2 sensors and so on.
2. TUNEABLE ECU - is illegal. There is nothing to stop you changing the tune as you drive out. Therefore PFC's are illegal
3. The EPA know the colour of factory injectors for RB25's/RB30et's etc, non-factory injectors means a bigger ECU... illegal
4. A larger turbo flows more air/boost etc. And alteres emissions, they are also... illegal
How would i know they are illegal?
- The information/laws clearly say so
- Time and time again people have been failed for them (including myself)
See this thread. The EPA Guidelines are clear as a cloudless sky.
If you were 'lucky' 'once' to get passed in a car that has nothing to do with the one in question, so be it, we dont care.
http://www.skylinesaustralia.com/forums/t156269.html
No more need for this as its all attainable information from the EPA.
Guest
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
