Hey i just need some help regarding the wiring on the intank fuel pump of a R32 GTS-T, Id like to wire up a hidden killswitch.
So which wires are which? Thier are four or five, i assume some are for the fuel level sensor and some are the power for the pump. Should i put the switch accross the - or the + line?
https://www.sau.com.au/forums/topic/18904-fuel-pump-wiring/
Positive is better. If you run it through the earth then a thief can instantly bypass it by running a wire from the negative terminal onto a nearby part of the chassis. If it's on the positive then he'd have to find the closest 12v line and run a wire the entire length from there.
https://www.sau.com.au/forums/topic/18904-fuel-pump-wiring/#findComment-396978
