EVERYTHING BUT SHELL AND SUSPENSION / WHEELS IS SOLD!
UPDATE - If anyone is interested in the car with a standard motor / gearbox for a lot lower price then let me know. Also can go even lower with a standard interior and wheels.
Hey all,
To give you a bit of history, i purchased the car about 2 years ago and drove it around for about a year. I then got defected for gauges and tires and things like that and decided to take my car off the road for a complete ground up overhaul. The result of it all was around $70000 spent and a car that is currently in a undriven condition with almost 80% of its parts brand new and replaced. It is currently in the shop at ATS (Allstar Tuning Systems) as the guys there were finishing off all the final stages of the build and preparing it to be back on the road. The sole reason i am selling the car is because i have had an offer of a R34 GTR come across which at this stage it to good to refuse. The specs of the car are as follows -
EDIT - Forgot Some Basics
- Late 1995 Model with S2 Running gear, approx 105000km's when it was taken off the road for overhaul. Car is registered until next year sometime i can't remember when exactly.
Body
- Full respray in House of Kolor Planet Green (Imported from US)
- Body Kit is 400R, Front bar has been customised.
- Body kit has been completely molded to the car not including the front bar, this process is very time consuming and expensive and it looks amazing.
- Door handles and antenna both shaved
- Guards (Under guards where wheels sit) have been completely polished back and re-coated lightly with black sound deadener (To make it look new)
- Under body of car has been cleaned and re-coated lightly with sound deadener (To make it look new)
- Carbon Fibre Bonnet
- M3 Mirrors (Electric)
- Shaved indicators from front guard
Engine (To be updated)
- RB25/30 Conversion
- Block done 20thou, Crack Tested, Acid Dipped and a few more things i cant remember (to be added)
- ACL Pistons
- Spool Rods
- ARP Bolts
- Tomei Cam Gear
- Ported and Polished Head
- Tomei Cams (Intake and Exhaust 256)
- Custom Fuel Rail
- 680cc Denso Injectors
- Bosch 044 Pump
- NGK Iridium Plugs
- Cosmetic Metal Head Gasket
- Oil Cooler and Relocation Kit
- Cusco Catch Can
Intake Side
- Greddy V-SPL Intercooler Kit
- Apexi Pod Filter
- Greddy Plenum
- Q45 AFM
- Greddy BOV
Exhaust Side
- Trust High Mount Manifold
- Garret T04Z Turbo
- Trust Wastegate
- Custom Dump Pipe
- 3.5" Exhaust
- XTR Turbo Heat Bag
Driveline
- Rebuild gearbox with Cross Cut PAR Gearset
- 1st to 4th Gears
- Helical Input Gear
- Replaced 3/4 Hub / Sleeves
- Energizer Pad Spring
- NEO 75/90 Oil (Like over $200 for the oil, and i have enough left over after build for a service)
- Exedy Twin Plate Clutch
- Rebuilt Diff with Polished Cover
- 19" Racing Hart Wheels (Light Weight)
Suspension
- HSD Systems Coil Overs
- EBC Greenstuff Pads
- DBA Slotted Rotors
- All Arms / Sub Frame etc powder coated in silver
- All Bush's and rubbers replaced with polyurethane whiteline items
- Camber Kits both sides
- Whiteline rear Sway Bar
- Cusco front sway bar
- Rear Subframe alignment kit
- All Bolts electroplated chrome
- Driveshaft bolts replaced
- HICAS Lock Kit (Tomei electric type)
Interior
- Full retrim in cream leather and suede by Extreme Trimming
- Full set of autometre lunar series gauges (Tacho, Air / Fuel, Nitrous, Fuel Pressure, Boost, Water Temp, Oil Pressure)
- All guages have been moulded in around the interior (Literally the whole dash is custom made, the pillars and the centre console)
- Apexi AVCR (Possibly Sold)
- Trust Turbo Timer
- Isotta Steering Wheel
- Isotta Gear Knob
- Isotta Side Steps
- Isotta Hand Brake Knob and leather
- Incar2 Racing Cluster (White background that glows green to suit gauges)
- Custom Parcel shelf to suit 6 1/2" Splits
- Custom Doors with fibreglass pods to suit 6 1/2" Splits
Miscellaneous (Brand new parts from Nissan)
- Bonnet support rubbers replaced
- Inner guard splash guards replaced
- Front window seal replaced (The whole plastic piece and the seal that sits around front windscreen wipers, commonly on skylines the seal starts coming apart. Genuine Nissan Part)
- Rear Boot rubbers replaced
- Gearbox seals replaced
- Headlight / Taillight bulbs all replaced
- All windows reseated and new seals installed
- New drivers electric window mechanism
- Wheels bearings / hubs replaced (The complete bearing assemble and unit the wheel bolts onto)
At the moment thats all i can think of, i know I've missed quite a few things and I'll add them at a later date. Almost all the parts here are brand new fitted to the car over the last year and literally never seen more use then being rolled off the tow truck into the shop. The paint hasn't even seen the sun for longer then an hour... This is a very painful sale as you can see, i've built this car with everything i've had over the last year and I'm selling it before i even get it back together and drive it. It's being sold in its current condition which is basically complete minus the engine / gearbox and interior being installed at the moment. However if the buyer wishs to do so I'm sure we can come to an arrangement about refitting and that kind of thing. The car is currently at ATS (Allstar Tuning Systems) the guys there performed all the rebuild work, the gearbox was done at TOP COG on the sunshine coast. Receipts are available for well over $50000 of modifications.
The guys at ATS will obviously vouch for the quality of all components as its all brand new. I am selling the car as a whole to begin with, if i have no luck i will sell off parts individually.
Please be patient with pictures, this has been a fairly sudden decision and as a result i do not have pictures of everything, i will post what i have to give you a good idea and add more later on. Feel free to call or SMS on 0419741040 my name is Ben. I am at work tomorrow and Sunday for most of the day so leave a voice mail message or text and ill reply. Alternatively PM me here for info.
I'm looking for around $35000, although i am negotiable so don't hesitate to throw me an offer. I will tell you now though, if you send me a ridiculously low or unrealistic offer your PM will be ignored.
These are the more recent pics
post-4555-1192198985_thumb.jpg post-4555-1192198945_thumb.jpg post-4555-1192198958_thumb.jpg
post-4555-1192198967_thumb.jpg post-4555-1192198975_thumb.jpg post-4555-1192198929_thumb.jpg
post-4555-1192198996_thumb.jpg post-4555-1192199004_thumb.jpg post-4555-1192199022_thumb.jpg
These are older, just to give you an idea of the bonnet and interior gauges set-up. It is before retrim and everything like that.
post-4555-1192199791_thumb.jpg post-4555-1192199841_thumb.jpg post-4555-1192199857_thumb.jpg
Edited by Got Boost?
this thing was on car damain yer i notice form the custom dash
Yeah it was a long was a long time ago lol, would be a year or two now?
I am considering parting it out. If anyone is interested in particular parts let me know and from that ill decide what to do!
so, so, so good.. worth the cash :P no need breaking balls to build one from scratch :P
Thats exactly what i was hoping people would see! You don't realise just how much it all costs until you do it, this would be perfect for someone that wants a quick street / track car or a potential trophy winner. Saves you waiting months for everything to be built also... Thanks for the positive comment! :spank:
you can buy this or do what i did and do it from standard.. close to 25 - 30k later you have a fast r33.. with half the mods lol plus all the headaches along the way with PANEL SHOPS and MECHANICS... and PART SUPPLIERS..
Amen to that... i almost shot someone twice along the way, mechanics that do a good job and don't tell you just what you want to hear are hard to find. ATS was the most pleasant surprise i've had with the knowledge and honesty about the whole project and costs involved. They really know there stuff and the quality is second to none. Don't get me started on the panel shops...
what size r the racingharts also how much they set u back?
They are 19's, i cant really remember exactly how much they were, i know it was around 2.5k and then i bought the tyres after that! Have never driven on them either...
nice rims.. classy
goodluck with it all bud
Thanks mate, looks like i might be parting it out. Someone wants to buy the shell of me already!
Awesome 33. To spend that much time, money and effort on that car and to give it away for an R34 GTR without even getting it on the road, this GTR must be a killer of a deal ;)
GL with the sale..
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
