the actuator is the round gold coloured thing bolted to the side of the turbo. it can also be silver. has a small bar that opens/closes the wastegate. it has a vac line that runs off it. install your boost controller onto the line that runs from the actuator housing (gold/silver round thing) and away you go
sweet thanks, now im sure there is a certain direction to put it in tho yes? on the valve there are arrows pointing in 1 direction, do i put it in running towards the actuator? or away?
Edited by joeleo87
typically yes, the bleed valve arrow points towards the actuator. best way to test this is put the valve in and go for a spin, keep an eye on ur boost and if it seems to just not go or go to high, pull over, adjust and drive some more
got it on and all works good.
i got the valve from a mate and he lost the key for it, and he wasnt sure wat the boost was set to, i tested it out and its set for about 9 psi which is good for me, my try for 10 and c how i go ;)
thanks all for the help
