Hey everyone
I've been looking into getting a OS Giken gearset for my 32 GTR due to me stripping 4th gear because of stuffed syncros.
Afew questions for anyone that has had personal experience/knows about them.
What is the difference between the Hollinger type input shaft and the standard one? Which should I go for? Benefits?
How strong are these gearsets?
Can you change gears quick with them? Or do you have to baby the shifts?
I've also read that you need some other parts. What parts are they?
Thanks for your help
David
Edited by belo
https://www.sau.com.au/forums/topic/189263-os-giken-gearset/
Thanks for the input fellas.
Im still judging up on whether to go for this box or another standard one.
Does anyone know the difference between the Hollinger input shaft and the standard one?
What parts are needed from Nissan as i can get trade price there?
Lastly, What shop would you recommend in the Sydney area to put the gearset in?
Thanks again
Dave
  • 5 months later...
Thanks again
Dave
i believe the clutch spline is different for the Hollinger shaft. We run an OS in our 9 sec drag car (see latest HPImag)
Award Gearbox and diff at rydalmere are the OS gearset guru's. Terry does our box and is very experienced with them.
Thanks for the info Paul.
I might have to go and visit them to ask them some questions.
