Hi All,
I kind of need some help, the previous owner of my car made a mess of the battery tray when he miss calculated the hole and decided to cut 2 circles next to each other to install his FMIC, so now I've got this giant hole in the battery tray that looks like ass. Furthermore, to make matter worse, he used tin snips on the hot pipe side to fit the home made cooler piping in. It's terrible as you can imagine.
Just wondering if anyone can re-weld up these ass of a holes and re-cut nice perfect circles for me and make it look nice an tidy from top and from below.
I don't mind home jobs as long as it looks good and clean.
If anyone can help and for a reasonable price, PM me...
Cheers,
Johnny
Edited by johnnilicte
Hi All,
Cheers,
Johnny
Welding a recutting holes could be a pita.
Have you thought about grabbing a die grinding burr and grind the holes out to the new round (or other) clean shape.
Easy to do and you could even do it with an electric drill instead of a pencil grinder if you don't mind side loading the bearings for a while. Given it is only light plate it shouldn't hurt the drill much if at all.
If you go down this path I would suggest spend a bit of time taping joints etc where the grinds may end up. Once they get stuck in a join etc you will never get them out and they will rust leaving a shitty looking mark.
If the holes work out a bit oversize just make up a rubber sealing gasket or run in some pinchweld edging and make it look like that was how it was meant to be
Cheers
Edited by WRRR
Well legally tany hole cut in that area must be reinforced to return the rigidity back to that section of the car, so if you are willing to have someone weld in a reinforcement plate that has a clean hole in it then you are also less likely to encounter any stife from it if one day you go to engineer the car.
ok so here is what i would do if i was to keep that piping design.
Remove the pipe, weld in a patch panel of 0.9mm body steel, from the underside of the chassis. Then make a new hole for the piping around 3.5" and slightly forward as it seems to be rubbing on the front section. test fit to make sure all is smooth and no fouling.
Then, i would paint both sides of the patch with an etch primer then some chassis black paint.
get some cardboard and trace out a piece that will cover the battery tray right the way under the guard mount, all the way to the wheel well and back to the chassis rail towards the centre of the car.
Use that piece to cut out a Flat sheet of 2mm polished alloy so you can cover the entire area. mount that with screws into teh old tray. then you can cut a matching hole in that from underneath to match the bottom hole.
use that alloy sheet to remount those wires, install a catch can, radiator over flow.... etc etc etc
If you want it done as cheap as possible, you could follow the above, then cut out your patch panel and the patch, needs to me no more than 1mm gap all around, then just take it somewhere to get tig welded up, might cost you $50 to weld it depending on how good your cutting and patch is.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
