emanage comes everything including ignition signal adaptor too is it tuned? if so, what for?
E manage comes only with the basic adaptop. Yes there is a harness specific for certain vehicles. The last i saw it was about $150.
The injector and ignition harnesses are about $50 each if you buy locally.
This E manage was tuned to my R34 GTT manual at Chasers in Victoria by Paul who tunes rally cars around the world.
www.chasers.com.au
https://www.sau.com.au/forums/topic/189704-sold/#findComment-3418157
does the Greddy E-manage just plug and play ? :closedeyes: or need a auto technician to install it ? any software ?
No it's not just plug and play unfortunately.
It'll be good if you send it to be dyno tuned so that the air/fuel ratios can be adjusted accordingly. With the injector harness, it tunes the flow of the injectors. Had friends with 740CC nismo injectors running on e-manage.
No software. Your tuner should have one.
https://www.sau.com.au/forums/topic/189704-sold/#findComment-3420278
The emange works with er34gtt tiptronic?? Whats needed to make it work apart from pluging it inn? i can be emailed at [email protected] or www.driftsideracing.com
Whoops just read the replys :)
Edited by DSR
https://www.sau.com.au/forums/topic/189704-sold/#findComment-3423406
Whoops just read the replys ;)
Yes it does work on the R34 GTT Tiptronic.
A tune will be needed apart from plugging it in :). I have all the harnesses as mentioned in the post :)
https://www.sau.com.au/forums/topic/189704-sold/#findComment-3427783
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
