emanage comes everything including ignition signal adaptor too is it tuned? if so, what for?
E manage comes only with the basic adaptop. Yes there is a harness specific for certain vehicles. The last i saw it was about $150.
The injector and ignition harnesses are about $50 each if you buy locally.
This E manage was tuned to my R34 GTT manual at Chasers in Victoria by Paul who tunes rally cars around the world.
www.chasers.com.au
https://www.sau.com.au/forums/topic/189704-sold/#findComment-3418157
does the Greddy E-manage just plug and play ? :closedeyes: or need a auto technician to install it ? any software ?
No it's not just plug and play unfortunately.
It'll be good if you send it to be dyno tuned so that the air/fuel ratios can be adjusted accordingly. With the injector harness, it tunes the flow of the injectors. Had friends with 740CC nismo injectors running on e-manage.
No software. Your tuner should have one.
https://www.sau.com.au/forums/topic/189704-sold/#findComment-3420278
The emange works with er34gtt tiptronic?? Whats needed to make it work apart from pluging it inn? i can be emailed at [email protected] or www.driftsideracing.com
Whoops just read the replys :)
Edited by DSR
https://www.sau.com.au/forums/topic/189704-sold/#findComment-3423406
Whoops just read the replys ;)
Yes it does work on the R34 GTT Tiptronic.
A tune will be needed apart from plugging it in :). I have all the harnesses as mentioned in the post :)
https://www.sau.com.au/forums/topic/189704-sold/#findComment-3427783
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
