hey everyone.
can someone help me out by finding out about this PROTEX Performance Ceramic Brake Pads? are they any good? i just need something that will do the job.. don't need performance brake pads as they are way out of my budget.
another thing is that don't really know whether this will fit my r33 skyline... the model No. is PROTEX Performance Ceramic Brake Pads db1165c.
i searched internet for about two hours and can find protex catalogue or anything... so if anyone happens to have the part number for r33 from protex or know that db1165c is for r33, please let me know... that would be much appreciated...
cheers in advance~!!! :closedeyes:
Well, a quick Google search revealed the following for DB1165 pads:
SUIT NISSAN BLUEBIRD U12 ZX,ZXE EFI ENGINE 1989 ON
U13 2.0L ENGINE 1993 ON
U14 1996 ON
Generally, Skylines use DB1170 pads in front, DB1220 rear.
Hi mate,
What are your requirements? If you're not specifically after performance pads, Lucas are dirt cheap, and good enough to win state rallying titles on. Above that you've got the usual horde of performance pads like EBC, Ferodo, QFM etc. Protex in general, be it their standard or performance range have always been good value for money, just a little harsh on rotors...
Greg
Talking of Lucas pads, where do you get them from in Sydney?
Any ABS Store sells them, and some other parts outlets as well. I've found that even with a $7 airbag I've been able to do them for less than most others anyway... If you get stuck trying to find somewhere let me know.
Lucas pads are very dusty though right?
Yep, but since they banned asbestos, that's the trade off with most pads. The only performance pads that don't produce a lot of dust is the QFM HP-X. Although not as good as the Lucas (650vs550) it is still as good as Bendix Ultimate, and easily enough for most road cars.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
