Hey there,
The last two of nights when leaving work (11pm) the car has been blowing a large amount of white smoke from the exhaust system. I'm not sure why, hence the reason for this post.
The car is a 1993 Nissan Skyline GTST
I've only noticed this white smoke on Tuesday night but didn't take too much notice thinking it was just because it was cold. But, It's happed again tonight and it's got me worried as its a little more then usuall on cold start-ups.
The car didn't seem to have any of this white smoke during the day - on start up or driving down to the local Autobarn.
Recently the car has had an oil change, oil filiter change and a few weeks before that had a complete coolant flush as the Water Pump needed to be replaced.
The car has also had a complete forged rebuild about 5 months ago, and also a Haltetc ECU installed about 2 months ago - I'm also running the stock turbo.
Tomorrow I guess I'm going to start with cleaning the intercooler pipes and probably check the spark plugs while I'm at it. Also have a small coolant leak which I'll also fix tomorrow.
Only other thing I think it maybe is the turbo seals, but honestly I hope its not!
I've tried to provide as much information as I could, but any questions or anything I'd be more then happy to answer them - really want this issue fixed :D
Thanks again,
Aron
https://www.sau.com.au/forums/topic/189885-white-smoke-on-cold-start-up/
white smoke = oil in exhaust,
now forged pistons, do expand quite alot from hot 2 cold compared to cast pistons and others, so ona cold motor the piston will b rather loose in the cylinder (some people even have knockin etc) maybe the oil you put in on the last oil change is a little thin and by-passing the rings when cold...
but most likely ur turbo seals are stuffed lol
Is this whilst driving? Idle? or load? plus noticed your in brissy, we have had some relative humidity lately at night time it could be condesation. need more info as per above
I've used Royal Purple SAE 10W-40 for quite a few months and never had this problem.
It's while the car is idle, once I'm driving I can't notice any white smoke but it's hard to tell when your in the drivers seat.
-_-StRyDeR-_-[/b]]i get the same, only in winter though lol. its condensation
Even on really cold start ups, colder then the last two nights I haven't had this problem. However, I noticed only one drip of condensation/water from the tip of the exhaust.
Edited by KustomR33
Alrighty, here's just an update,
I've fixed that coolant leak I had, I had another look at the white smoke I started it up this morning when the car was cold, and there is a minimal amount of white smoke, probably from the cold start?
Took it for another drive, power seems good, if not better then usual - I guess I'll have to see if it smokes tonight after work while letting the car warm up.
I don't think its the turbo seals, because if it was it'd be doing it all the time.
It could be the valve stem seals because it only happens when the car is cold, but its only happing at night so its confusing.
Maybe there's a little bit of oil in the intercooler piping? I'll give that a clean soon see if that gets rid of it.
Or, lastly, could just be my head :lol:
If anyone has any other ideas, suggestions please do let me know :)
Thank-you very much for your help.
White smoke on a cold start is more than likely water vapour condensing in the cooler outside air (the compustion process produces water, amongts other things).
But, not large amounts like I'm getting at night on cold starts?
White smoke is not from oil.. Blue smoke is oil smoke so i dont think it's blow by past your rings even with forgies these days thermal flex isnt like it used to be so i doubt it's that, or your valve stem seals.
good luck though come us updated but.
is it smoke or steam, next time it happens watch it as it comes out of the pipe, if it disapears after a meter or 2 its steam, if it hangs around in a cloud for a few meters its smoke.
When I first start the car it's steam, after a couple of minutes it becomes smoke.
Here's the latest;
Started the car tonight at work to let it warm up as usual, noticed white smoke again, reved the car a little bit and I got alot more white smoke and black smoke too.
It also smells like oil/fuel..
Could it be a bad dose of fuel?
Hey man what sort of breather system is on your motor? ie catch can?
my car went for a few weeks blowing white smoke similar to yours, it turns out the cank case was pressurising due to blocked breather lines. this was causing oil to blow out the rear turbo seal.
doesn't sound right but when I replaced the hoses to the catch can it went away :)
have a look!
have a look!
I'll check my breather hoses today, but I don't have a catch can on the car though.
By the way, thanks to everyone who has been trying to help me :D
Hopefully I can get it sorted soon.
Edited by KustomR33
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
