SAU QLD GAME.. take a stab. u may win a free drink
99 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
You game is ghey
At least supply a video of 'some' quality...
thats from a 5mp N95 Nokia.. tell MRbenno they are shit then... :(
it sounds like it's got too many mufflers... Weak Mark.
weak my ass
no one has guessed it..?? play my game bish.
revs slow..?? :P and speedo lags cause its digital.. 2nd gear. and goes much harder than a GTST
  • Replies 159
weak my ass
Yes, rev's slow. as in from x - 9000rpm it isn't getting there that quick...
It's got too many mufflers.
Nokia NXX phones rock, I have one myself.
Seeing Mark wouldn't shut up in whoretown about his forged 4G63 he was building weeks ago, I'd say your right.
no i worked on that again today.. its not the evo engine lol... but that 4G63 should be done soon.. just gotta do fluids and dash.. new shifter cables worked a treat from a JDM spec IT IS NOT THE 4G63
i reckon its fine. like to see a R33 gtst keep up with the silvia. anyway joshwa what was ur guess..?
20B tho not on your list.
no it aint. because the engine in the sil is on the list.
Anyone guess it yet
Anyone guess it yet
Ok, any R33 gtst? It's a deal.
I know its not the 4G63 from above, it's not an RB, SR, L28, VH, VQ. It's not an LS1. It's not a JZ motor, it doesn't sound VG enough or CA enough, but it does sound like a toyota motor.
I keep thinking it's a 7m, but I know you know better then to use a motor that shits head gaskets, so my guess is its either a 3S or a 4A
lock it in.. car has standard compressor so bring me a R33 gtst with standard compressor and well race at the bank. no NAWSS :)
of course it aint a 7MGTE u think i would go to the effort of pulling one out and in.
far out u guys are gonna kick urself when u realise what it is..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
