Hey guys i have a n/a r33 series 1 (rb25de),
my car blew the injector fuse, which stock is 10 amps. And it kept blowing 10 amp ones so i put a 30 amp in to get it home n stuff and that blew too so its blowing 30 amps, sometimes car will start and idle for a bit then just turn off and sometimes it will just tick tick tick tick tick tick and not even do anything. So as it has started up then drops out im guessing its something to do with the injectors itself?
Can anyone help me? please! duno what to do.
thx, Leigh.
https://www.sau.com.au/forums/topic/189989-injectors-stuffed/
Id be looking for shorts in the injector harness... get ur hands on a good digital multimeter if u can and test the power and earths near the plugs on the injector harness, there should be almost no resistance.. if there is u have a problem somewhere.. it sounds more like a job for an auto electrictian rather then a mechanic.
i will have to do this tomorrow, thx for the reply keep em coming people
leigh
f**k sakes, took it to mechanic they had it for 2 days said they checked over everything wiring etc said it was fine and they couldnt find a problem and cost me 165 dollars, driving home thinking yea nothing to worry about now and in my street guess what? blows again.. so not very f*kin happy atm, i have no f**king money either.
mechanic i took it to was the place i bought it, luxary and performance vechicles or something in boronia..
:cheers::P:):rant: :rant: :rant:
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
