I have installed my emanage ultimate and found I have an intermittent missfire. Mainly at idle and when holding around 5% throttle at any revs. After doing a datalog on the emanage, the missfire looks like the injector duty cycle is spiking to 99% intermittently. This is on the input duty cycle coming from the standard ecu. I have double checked all of the connections and no fix. It seems to be only one cylinder at a time missing (same cylinder or different ones im not sure) Car runs fine under load and the injector duty cycle acts as normal. I have noticed a few times when backing off from high rpm's, the duty cycle will spike up to 90 -95% and then gradually decrease to about 80% with the revs before dropping back down to 5% where it should be.
Does anyone know why the standard ecu would be spiking the injectors to nearly 100% duty cycle intermittently? Stuffed ecu or could it be something else like CAS. Attached the datalog for anyone who has the emanage log viewer showing the duty cycle input spikes.
r33.zip
I had the EXACT same problem with my R33 using an emanage ultimate. Had me and my tuner stumped, Would spike the injectors to 99% duty cycle for a split second whilst at light throttle.
Have heard that this was a fault with some EMU's, not too sure how true it is though. I ended up selling the EMU and getting a pfc instead, Cheers shane.
Damn thats not what I wanted to hear! Re-soldered all of the contacts again, still doing it.
The board I have is a D board although its a late serial number : 05076.
Also had a look at the bottom of the circuit board, and it looks like the aluminium retainer rail of the case is coming into contact with the tiny contacts on the board. Ran a length of insultation tape over the length of the board as a precuation.
mine does it too
I Have bought a Injector adapter harness but havent put it in yet (dont know if it will fix it ,but they say its to stop it running rich)
I also found that when it was missing at idle if i upped the revs to around 800Rpms it would go away
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
