Originally posted by bbenny
hey price is about $19.50ea
I dont know what u should gap them too. i know for turbo RB engines its 0.8mm but on the packet the iridiums say not to change the gap because the tips are very fine and fragile.
I gapped them to 0.8 anyway and they have been pretty good.
By gapping expensive iridium spark plugs, as far as i know, voids the purpose of getting expensive iridium spark plugs, as what you pay for is the coating, which is removed when you gap them.
I may be wrong....
  • Replies 44
well i gaped them by tapping the top of the bent curve without fitting anything in between just to make sure no surfaces were scratched, so there was no chance of the coating being removed. i then just used a feeler guage to check gap distance.
Worked perfect, much better than the platinums. so im sure its not a problem as long as you are careful.
Iridiums are gapped at 1.1 by default. I am using them at 1 bar boost and have absolutely no problems, the mixture is perfect and there are no flat spots or anything, so I'm not sure why you'd need to regap them when running any normal sort of boost. Maybe with even higher boost you might need to gap them a bit smaller, I don't know.
Ths only platinums I've used are the old ones that were in the car when I got it, so I can't really say if the Iridiums are "better". But everyone seems to need to re-gap their platinums, so for not having to re-gap the iridiums makes them seem worth the extra couple of bucks to me. Not for the time/effort saved, but the fact that you can have a more universal gap (ie just forget about it).
  • 1 month later...
akeenan: in your great wisdom, can you tell my why my NGK coppers melted? I think that Coppers are only asking for trouble after the latest stint..... All of the plugs were stuffed (the little finger was melted off ever single one). I think after that I can justify the price of iridiums
Sumo
I have to correct myself about the Iridiums gap too. I'd been told that it was 1.1mm. I decided to expierment with changing the gap awhile ago to help eliminate flat spots. I pulled the first plug out and checked the gap, and it was 0.7mm. Oh well, nothing more to do there :)
the only ngk plugs specified for a r33 gtr are platinum or iridium no copper ( i'm sure u can find copper though but wouldnt last )and the diff in price is only $2 , iridiums last a bit longer , i dont know that they are any better though .
Sumo
no i cannot tell you why they melted. sorry..
Running lean or detonation is the main cause of plugs melting isn't it? If so, maybe copper plugs would serve as a good warning device. Better a melted plug than a melted piston!
I am under the impression that the new technology plugs come set at the right gap for the application. Correct me if I'm wrong, but setting the gap in sparkplugs was dome in the low-tech days when the electrode wore away much more than it does with electronic controlled ingnition systems.
what heat range would be best for RB25DET? I was told heat range 6 is good, but some ppl here uses heat range 7??
At what boost level you should use 6 and 7?
And someone also told me the suitable gaps is 0.8mm ?
using platinum or iridum they can have a very fine tip witch produces a better spark . u can have a fine tip with standard nickel but the life expectancy would be very short thats the reason the nickel tips are much bigger ( longer life )the platinum on the tip doesnt burn as easy so it lasts much longerand iridium longer still ( they claim iridium give a better spark as well .
i wouldnt use nickel on any of my cars , i only use platinum but next time i'll try iridium as they are only $2 more .
there are 2 types of iridium ngk sparkies....
the difference is in the centre electrode (tip) size.. 0.8mm and 0.6mm.
0.8 is the same size as plats so they are only better by lasting longer.
0.6mm one has better spark and uses less voltage but only lasts same distance as the platinum ones. also when you order em make sure u tell em to get the model without the -11 at end cause then they will come gapped to .8mm not sure the code for the RB's. you dont want to gap them the traditional way cause you might scratch off the iri coating which defies the getting em in first place!
i used to use the v-groove copper ones but with the iridium's engine does feel smoother and seems to hold boost better.
just put platinums in mine and noticed a slight improvement. dont know if the iridium ones would make much difference. a few guys i know have said that they didnt notice any difference between platinums and iridiums. they will probably just last longer.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
