Originally posted by bbenny
hey price is about $19.50ea
I dont know what u should gap them too. i know for turbo RB engines its 0.8mm but on the packet the iridiums say not to change the gap because the tips are very fine and fragile.
I gapped them to 0.8 anyway and they have been pretty good.
By gapping expensive iridium spark plugs, as far as i know, voids the purpose of getting expensive iridium spark plugs, as what you pay for is the coating, which is removed when you gap them.
I may be wrong....
  • Replies 44
well i gaped them by tapping the top of the bent curve without fitting anything in between just to make sure no surfaces were scratched, so there was no chance of the coating being removed. i then just used a feeler guage to check gap distance.
Worked perfect, much better than the platinums. so im sure its not a problem as long as you are careful.
Iridiums are gapped at 1.1 by default. I am using them at 1 bar boost and have absolutely no problems, the mixture is perfect and there are no flat spots or anything, so I'm not sure why you'd need to regap them when running any normal sort of boost. Maybe with even higher boost you might need to gap them a bit smaller, I don't know.
Ths only platinums I've used are the old ones that were in the car when I got it, so I can't really say if the Iridiums are "better". But everyone seems to need to re-gap their platinums, so for not having to re-gap the iridiums makes them seem worth the extra couple of bucks to me. Not for the time/effort saved, but the fact that you can have a more universal gap (ie just forget about it).
  • 1 month later...
akeenan: in your great wisdom, can you tell my why my NGK coppers melted? I think that Coppers are only asking for trouble after the latest stint..... All of the plugs were stuffed (the little finger was melted off ever single one). I think after that I can justify the price of iridiums
Sumo
I have to correct myself about the Iridiums gap too. I'd been told that it was 1.1mm. I decided to expierment with changing the gap awhile ago to help eliminate flat spots. I pulled the first plug out and checked the gap, and it was 0.7mm. Oh well, nothing more to do there :)
the only ngk plugs specified for a r33 gtr are platinum or iridium no copper ( i'm sure u can find copper though but wouldnt last )and the diff in price is only $2 , iridiums last a bit longer , i dont know that they are any better though .
Sumo
no i cannot tell you why they melted. sorry..
Running lean or detonation is the main cause of plugs melting isn't it? If so, maybe copper plugs would serve as a good warning device. Better a melted plug than a melted piston!
I am under the impression that the new technology plugs come set at the right gap for the application. Correct me if I'm wrong, but setting the gap in sparkplugs was dome in the low-tech days when the electrode wore away much more than it does with electronic controlled ingnition systems.
what heat range would be best for RB25DET? I was told heat range 6 is good, but some ppl here uses heat range 7??
At what boost level you should use 6 and 7?
And someone also told me the suitable gaps is 0.8mm ?
using platinum or iridum they can have a very fine tip witch produces a better spark . u can have a fine tip with standard nickel but the life expectancy would be very short thats the reason the nickel tips are much bigger ( longer life )the platinum on the tip doesnt burn as easy so it lasts much longerand iridium longer still ( they claim iridium give a better spark as well .
i wouldnt use nickel on any of my cars , i only use platinum but next time i'll try iridium as they are only $2 more .
there are 2 types of iridium ngk sparkies....
the difference is in the centre electrode (tip) size.. 0.8mm and 0.6mm.
0.8 is the same size as plats so they are only better by lasting longer.
0.6mm one has better spark and uses less voltage but only lasts same distance as the platinum ones. also when you order em make sure u tell em to get the model without the -11 at end cause then they will come gapped to .8mm not sure the code for the RB's. you dont want to gap them the traditional way cause you might scratch off the iri coating which defies the getting em in first place!
i used to use the v-groove copper ones but with the iridium's engine does feel smoother and seems to hold boost better.
just put platinums in mine and noticed a slight improvement. dont know if the iridium ones would make much difference. a few guys i know have said that they didnt notice any difference between platinums and iridiums. they will probably just last longer.
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
