According to Mine's the engine was not bored for bigger pistons to preserve the reaction,which was posted on youtube. and it showed to be true,the rpm was revved up from 4rpm to 8.5rpm in mere miliseconds. but contradicting this are those stroker kits offered by HKS(2.7L) and Apexi(2.7 or 2.9L) kits and also the RB30DETT offered by tomei(Which needs the engine to be bored to fit in bigger pistons). which i think is also awesome cos i had a chance to sit in a 2.9L R34 GTR tuned by a well known local tuner. i felt that the response was not as i thought it would be. and the lag was there,but after 2 seconds everything kicked in and it blew me away. even with the power that these stroker kits offered,i was more concerned about the reaction of the engine. this comes in when taking in corners and i wouldn't want to have the stroker kit mess the traction jus because it stroker kit didn't respond quick enough.
So my main doubt is,wat are your comments on this subject? once the decision to bore the engine,there's no turning back,but in return more power but less response. :O
https://www.sau.com.au/forums/topic/190138-to-bore-or-not-to-bore-the-engine/
what other factors are you referrin to?
regarding the other parts of the car,most of it has been changed,
ECU : Power FC
Camshaft: Tomei
Cam pulley: Tomei
Fuel injectors: 800cc SARD
Hks timing belt
Fuel pump: 265L
Hks front pipe
Hks gt intercooler
trust oil cooler kit.
Hks evc 4
Hks intercooler piping
Tein monoflex with edfc
koyo radiator
sard radator hose
considering this are all external items,when it comes to pistons,crank shaft and crank pulleys,i would want something that delays the response as to me beating other cars on the strait road jus based on the horsepower,is something anybody can do. having an overall balance on the car is my aim.
bore size has very little to do with it (only a difference of 1.5mm maximum, and pistons prolly lighter if forged anyway)
it's the stroke, reciprocating weight and component balancing that makes all the difference to an engines eagerness to rev
thanks man. i'll look into these things and research more into the developement of the engine.
anyway,do you know how i can get to Hi-Torque Performance in melbourne? or are there any other places you would like to recommend?
Boring a block doesn't noticeably increase lag at all.
Your talking a poofteenth of space dude.
Boring a block is generally to get out imperfections when doing a rebuild due to a failure or otherwise (and hence why you are rebuilding).
Lag/response etc has far more to do with the turbo selection/tune and various other things
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
