Vehicle:97model series 2 type M r33 skyline
Milage:137 800km
Colour:silver
RWC supplied?can be
Currently registered?yes
Price:$16g or im mainly after swaps..
Contact:pm me, if your interestd and in brissy, we can meet up and talk
Comments / Modifications:car currently sits on a full set of 17inch rims, and has no spoiler
Apexi turbo timer
Apexi SAFC
Blitz pod filter
Blitz LM front mount intercooler
Exedy HD clutch
GFB Bleed Valve
Screamer pipe welded into exhuast system(legal)
Cusco 2-way LSD (very tight)
Mongoose Alarm & Immobiliser.
jic coilovers
brand new jvc headunit with geuine nissan pocket, all new 6inch jvc speaker front and rear
17inch rims all round with near new tyres
front & rear strut braces
new power window units
battery relocated to boot..
auto window wind up, auto fold mirrors..
rewired safc and new alarm
new rubber on cooler piping
recent servie done by motive, i have not touched the boost controller, which is running stock boost still....engine has 137**kms on it..has not missed a beat, all filters etc: changed with service..all receipts etc...log books...personalised plates will also come with car unless i get another 33(i dont know y i would, id rather keep this 1)....this car is my daily driver so..there is nothing wrong with it..always warmed up in the mornings and cooled down 30sec by timer...no spolier on car either..
Images:yep
NOTE: THE CAR NOW HAS NO SPOILER, FULL SET 0F 17INCH RIMS AND HAS A BRAND NEW JVC HEADUNIT AND GEUINE NISSAN POCKET!!..also the gear knob is now straight aswell:P..
Edited by GHO57
https://www.sau.com.au/forums/topic/190197-series-2-r33-97model/
well not really drifted..but skids..(legal track skids of course),theres no performance mods other than exhuast and front mount, so internals are kept happy,since i got the car the i took the rims off a put the full set of 17inch rims on it..its always run stock boost with me and the previous owner..the owner before that put the boost controller on a set it to 10psi..now running standard 7psi..and with regular services ive looked after the engine and the internals are kept happy..no leaks no spikes..no noises coming from anywhere..feel free to check it out..thanks mate
Edited by GHO57
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
