Thought i'd put this up for Anthony.
17/11/07 8am start. (maybe 28th aswell depending on numbers)
Turbotechnics workshop - unit 2/89 Mitchell St, Cardiff NSW (2 wheel drive Dyno)
Entry Fee : $50
Includes 3 ramp runs and dyno printout.
Application forms will be available from 27/10/07 (from Turbotechnics)
Entries are limited , so book early to reserve your spot.
Entries close 4pm 9/11/07
Trophies awarded to top performers in these categories:
1) 4 cylinder naturally aspirated
2) 4 cylinder forced induction
3) 6 cylinder naturally aspirated
4) 6 cylinder forced induction
5) 8 cylinder naturally aspirated
6) 8 cylinder forced induction
7) Highest Overall
Sausage sizzle and cold drinks available on the day
For more info call : 02 4954 5466
Edited by yye-33w
me and some mates are doin a kk's run this sat nite wanna come?
Would love to but I'm pretty busy all through this weekend sorry!
Take some pics?
Paul - you going to come along to this (get another lil' trophy to add to the collection..?) :P
More info on this event. - I am going to push my car to 30psi for this day :teehee:
TURBOTECHNICS DYNO DAY
Unit 2/89 Mitchell Road Cardiff NSW
For those of you who have been to our last Dyno Day you will know that it was a great
success as we ran over 45 cars on the Dyno.
You are invited to join us on the next Turbotechnics Dyno Day on Saturday 17th November 8am
At Unit 2/89 Mitchell Road Cardiff NSW.
There will be Trophy's for
- 4 CYL NA
- 4 CYL Forced Induction Highest Overall
- 6 CYL NA
- 6 CYL Forced Induction Overall
- V8 NA
- V8 Forced Induction Overall
- Highest Horse Power Per Litre
There will be a BBQ & Cold Drinks available.
Running your car on the Dyno can not only determine how much power you are running at the
rear wheels, but we can also give you a print out of your air/fuel ratio to check that your
pride and joy is running correctly, if its not we can advise you on what direction to take
to tackle the problem, for $50 for 3 runs you cannot go wrong!
Print outs available.
Power - KW
Power - HP
Torque
Boost Pressure
Air Fuel Ratio
Lambda
+More!!!
Pre-booking is preferred as you will get priority over unbooked cars.
For more information please check out our web site, www.turbotechnics.com.au or phone
Anthony on 02 49565466
See you there!
guys
this day is going to be huge, we have got 20 entrants paid in full ready to go allready and from what i am hearing there are going to be ALOT of cars turning up on the day to run.
We will have to cap the car limit at 50, so you are better off pre-booking now or turn up early on the day and get your form in early otherwise we may have to turn cars down because there are only so many hours in the day!
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
    • I do this, I also don't get the joke
    • Return flow cooler will be killing you I reckon. You can certainly push more through a low mount setup but they're good numbers for a stock looking engine bay.  Mine made 345rwkw (hub) at 22psi on 98 with a "highflow" on a stock manifold but it's a long way from a normal high flow or standard engine. I used one of those Turbosmart IWG-75's and it was great with the Motec running closed loop boost with pressure being applied to both sides of the diaphragm.
    • Hey man do you have pic of adaptor plate by any chance I need to match up the bolt holes as my gearbox adaptor plate ones are way off the only bolts of starter motor are matching thanks
    • Do they always do it from the AFM? If so... You know what I'm already thinking I reckon...
