Hey guys,
So i was sitting on my computer.. kinda bored.. and decided to go through threads and pics (mainly vic and photography section) from the forums and print up a lot of pics to stick on my wall in my room.
After time my fingers were killing me from all the blu-tack and sticking and i still got more pics to put up. :P
Check out the pic of my wall :D can you spot YOUR car? :P
If you cant find yours and want it added just post your best picture here and ill add it to my 'wall of fame!' lol
Leigh.
https://www.sau.com.au/forums/topic/190797-i-was-bored-and/
  • Replies 46
Posted Images
really? iuno how people are finding it weird and creepy :s might have to take em down n just leave a few of the highly modded ones.. seemed like a good idea at the time! needed a break from all my exotic car posters around my room
https://www.sau.com.au/forums/topic/190797-i-was-bored-and/#findComment-3435087
lol i was jus jokin... i'd usually go for posters from mags...
I can't talk... I've got two bus shelter posters (6 foot x 4 foot) of Optimus Prime and Megatron from the transformers movie on my walls.
https://www.sau.com.au/forums/topic/190797-i-was-bored-and/#findComment-3435100
actually it said it was low and needed replacing so i just printed off pics n shit till i had to put new ink in, so much for 'low ink' aye
cover the whole wall with skylines...... :D:P
now...its maggi noodles time...and possibly fast and the furious 1 2 and 3
https://www.sau.com.au/forums/topic/190797-i-was-bored-and/#findComment-3435106
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
