pretty fkd up
me and alot of mates from skool went to our skool tonight coz its muck up day tomorrow
security guard called cops n they came n chased us
few of us got away but then got phone calls saying to come back other wise we are getting expelled and locked up so we did
got made to lie on the floor and cops were being biggest fk heads
one of em kicked my mate and one got in my face and asked me if i thought it was fkn funny...i said no lol
any who got put in a patty wagon and got taken to the station on wakefield st.
i rang my sis to come get me.
the fkd thing is the ones who g ot caught are the ones who did nothing and the ones who actually did shit got away some how.
cops are the biggest wanks saying were gonna go to juvy for 6 years and shit
well got skool tomorrow (actually today seeing its 1 30 am) hope dnt get in to much sh*t at school wish me luck lol..and yes i know shouldnt of been there but hey you learn by your mistakes
ay.
just thought i'd let yas know.
https://www.sau.com.au/forums/topic/190811-arrested/
  • Replies 42
lmfao.
I'm with Dan on this.. Situation surrounding as if you go back. hahah. :/
At least if there's a next time and you get asked why you ran or didn't go back you can share this wonderfull experience of people being kicked etc for no valid reason.
Well lesson learnt. :D
But what did you or others actually do?
https://www.sau.com.au/forums/topic/190811-arrested/#findComment-3435357
yer fair enough the cops are ment to their job im not hating em for that but they didnt need to kick my mate and call us f*ck heads and shit.
Only reason we whent back is coz my mate got a call and it was a mate who had got caught n the cops were saying to get back other wise we'll get expelled n get locked up...but the only way they would of known that we were out there is if someone who got caught ratted us out...which pisses me off.
well im off to school probs gonna get an ear full from the principal :D
its gonna be a good day :/
i'll keep u guys informed on what goes on today at school lol
https://www.sau.com.au/forums/topic/190811-arrested/#findComment-3435360
lmfao.
I'm with Dan on this.. Situation surrounding as if you go back. hahah. :D
lol i know i wish i just sed fk it and ran home lol ahh well
apparently eggs were thrown and the coppers said they found spray cans but no one had spray cans :/
they'll probs trying to scare us while on their power trips lol as if we'd go to gaol for 6 years lol
well off to school i'll keep ya guys posted lol
catch ya
https://www.sau.com.au/forums/topic/190811-arrested/#findComment-3435372
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
