Make: Nissan
Model: Skyline
Milage: 121000
Colour: Black with gold glitter
RWC supplied? Yes can be supplied through negotiation
Currently registered? Yes Jan 08
Price: 15k- Just make an offer
Contact: PM me or call me on 0405003656 (Possible to arrange a time to meet me at work in Port Melbourne)
Comments / Modifications:
This car has had no major modifications and has drives great. This car is great with little defect opportunity due to the untouched engine, awesome blow off sound without having a blow off valve (importer did something makes is sound awesome). Engine bay is clean and have had no hassles with cops as exhaust is under 90 db. Im open to all offers
Exterior
Spoiler- Gtr/Custom
400 r Front BAr
GTR side skirts
GTR rear guards
Front Mount Intercooler
Gold Glitter Paint
Speed Light 17" Rims-White
Fully Adjustable Coilovers
Heavy duty clutch
Full 3" Exhaust plus cannon
Air Filter Pod
Interior
remote start/pager alarm
Head unit
Full automatic turbo timer (think its hks i'll check tomorrow)
Boost guage (not installed)
Tachometer (not installed)
Going to put new tyres on this week WOW!
Bad points
Slight front bar damage and chips, barely noticeable though
Left rear quarter panel and gaurd slight scratching again barely noticeable
A very clean R33, theres mores to add but cant think right now so just ask!
Images:
Edited by jayglong
https://www.sau.com.au/forums/topic/190946-r33-95-gtst-manual/
10.5k no reg/ rwc (rwc, will need 4 tyres and some nuts one on each wheel!) can take you to my mechanic, who's 'very' good with imports, for this w/e sale, got a few cars lining up to be bought and need cash.
Edited by jayglong
CAr is still available. Sorry dont have stock wheels for it. basically i cant manage/ deal with this car as i've purchased 1 for business and other for project which needs to be paid. rwc will need tyres (around 400 for reasonable low profile) nuts, (about 40 if you want lock nuts, or cheaper for standard) windscreen wiper blades. Singular bolt on body kit (may not even be noticed/needed as body kit is secure) not going to go lower than 10.5. No rego=no plates. All up it will be about 3.5k cheaper than what i asked, It's cheaper like this for you guys as it give you the time to fix up things.
Edited by jayglong
I really need this gone! its just sitting there, all by its lonesome, have only driven it 21km since i put it on sale. and have been driving it for 2 and half weeks on one tank of petrol. thats how little i've been driving it. Basicaly just drive it down the street for a bit of attention from blow off thingy. i'll sell today for 9.8 cash, but just today. any takers?
Might consider it if you take the GT-R badge off the front grill. Lol
On a serious note, a friend of mine is looking to buy a Skyline - how much can you do with RWC?
haha, thats what i said when i first bought it! previous owner glued it on and what not so didnt want to touch it cause of the mesh. as mentioned the above rwc doesnt require much, just have no time. cause im working for myself and part time. So no time, its priced cheap so you will be saving money regardless.
Thanks for comments
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
