I find that after driving along a freeway or over 100km/h for more than 15min my orange HICAS light comes on display in the dash.
is that normal?
Because i have fitted an aftermarket wheel, and the boss kit for the wheel meant i had to turn the steering sensor to align with the boss kit.
https://www.sau.com.au/forums/topic/19096-hicas-light-comming-on/
Thsi happens to my car too, and a lot of others I know. Its nothing to worry about.
If your concerned, go to a performance shop and get them to look at it.
Don't bother talkin the boss kit off again, I fitted one of them to my car, I know what a c#nt of a job it is!
This happens to a lot of skylines,
one fix is to change lanes every 10 or so minutes and it wont get the problem the other is to go and get the hicas re calabrated (to sute the amount you moved the sensor ring) I only know of one shop that dose this and he is on the gold coast in Qld.
thanks i whish i knew that 2yrs ago coz on a 32 i did it this way u take out the instrument cluster pull apart the speedo there is a glass tube with 2 contacts that touch each other just solder then to gether this is what i did {execpt the solder part} just got to pull it back apart and sollder it then my hicas can work agian
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
