Hey forum how the hell are the greatest bunch of guys and gals this side of the world? Need some advice so I came to the experts. What I want to know is if you have a piggy back that is tuned with these mods shielded pod with cai, fmic, 3.5" turbo back exhaust with split dump, boost 10 lo and 12 hi on stock turbo and always run 100 octane fuel will advancing my ignition time give me any gains? Of course if it does I will retune when I am getting it done. Or with the piggy back tuned that means the ignition timing is already advanced? All help is appreciated and welcomed!!!!!! THANK YOU GUYS IN ADVANCE!
https://www.sau.com.au/forums/topic/191187-advancing-ignition-timing/
http://www.skylinesaustralia.com/forums/t1....html&st=20
I asked this a while back.
Its not in the thread but I came to the conclusion to leave the base timing as standard and not touch the CAS, but rather buy a new ECU and advance the timing via the computer, hence a tune.
Thanks for the reply ppl its really appreciated. Just that my afc neo doesn't have that feature and really don't want to buy a pfc cus where I am at mod wise I am stopping and just wanted to get as much out of the ride as possible without modding any further. Rather buy a pfc for the gtr I am getting :rolleyes:. So just leave the cas alone cus for an extra 5kw might end up causing me a new engine not even 5 degrees would be safe even if i always run 100 octane fuel?
You can probably get away with it. Its just dodge doing it.
I mean you've got no way of monitoring if your motor is pinging apart from when you can hear it with your ears.
I'd sell the AFC Neo and invest that money towards a PFC. Believe me when you get it and have it tuned, you'll say that was worth it. Or alternatively buy the cheaper but effective EMU.
The tune of the AFC would probably be advancing the timing anyway, usually you cant advance it anymore or it starts to ping. As you lean out the mixtures, the timing advances, usually you cant lean it out enough, because it advances too far and detonates
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
