im trying to find a way to mount my emanage. its not very big, its around 150x250x25.
i want to mount it to the side of the centre console, just under the reach of the glove box when its completely open.
any ideas on how i can make something up to mount it there?
winner gets a chuppa chup.
https://www.sau.com.au/forums/topic/191337-need-to-mount-my-emanage/
dont believe him, he never pays up with his chuppa chups :rofl:
so you want it mounted behind the glove box ???
there is room under the dash there, and you will be able to mount it on the reo bar that links the 2 a pillars together and supports the dash and steering column.
pulls the glove box out and have a look in there, make sure it will fit, then you'll need to make up a "box" to hold the ecu unit, then a tube attachement to mount that to the bar.
lol you're -1 chuppa chup remember?
i want it to sit up against the centre console on the passengers side. but just out of the reach of the glove box.
i want it within reaching distance so i can switch the maps whenever i like as well as connect my lappy up to it whenever i like.
here is the only pic ive got of the size of it and where i want it mounted.
the pink part is the angle that the glove box opens, and in red is where i want the emanage ideally.
its got a few warning lights so if my temp, boost, timing etc reaches the limit i set it to, one of the lights change colour so i want it in my sight at all times.
ive got it sitting in the DIN console and im happy with it there but if someone can come up with a design for me to have it there that would be sweet, so i can re-install my gauges.
I've been considering places to mount the one I just got. One thing that came to mind was to make a custom bracket out of a flat piece of metal, by folding each side into an L shape. Then the main flat part could bolt to the underside of the e-manage, and then flat ends of the L could be used to mount it. In my case, I was considering putting it in the glovebox, if there's room.
well the main problem is finding 2 points to mount what ever is is you decide to hold the unit in.
it will need 2 points to hold it steady, since the weight and distance to mounting point with induce vibration/wobble.
i can only really envision a 3 piece system.
1 mounted and bent around tthe centre console from the left support behind the radio, this is the main centre dash support.
1 mounted onto the tunnel via the bolts holding the gear lever shroud.
1 mounted to the emanage that connects to these 2 pieces.
- Flip down from the ceiling?
- Use a DIN spot and build a motorized tray with some switches, worm drives and a PICAXE to control it all
- Mount it where you want it now, and use a sheet metal bracket that goes up underneath the right hand edge of the glove compartment door?
Iv been going through the same thing (on a smaller scale with PFC HC)
Iv made a bracket from sheet alloy, that holds the HC a little higher then in your picture, and secures down the left hand side of the top DIN slot. I don’t like it being on show all the time.
ATM I'm thinking bout a CarPuter. Could use that new "dial displaying" SW in development for showing output, DataLogit for tuning. Could run a Wideband output to the laptop too... true utopian all in one :rofl:
2 cents
Keep it in the DIN pocket and mount your gauges elsewhere?
IMO it's gonna be ugly hanging off the side of the tunnel, and how do you plan on hiding the loom?
Personally I don't like DIN mounted gauges. You have to shift your focus too far from your normal field of vision to check them.
I have mine mounted on the steering column and it's a quick glance down, as you normally would when checking speed/revs etc. I can still see all my factory gauges apart from oil pressure, which isn't accurate anyway and I have an aftermarket oil pressure gauge.
If you get a DIN pocket with the flap on the front, then the ECU can be hidden from prying/theiving eyes as well.
thats what ive done, its in the DIN pocket now. im looking for one with a cover, but i cant find one yet!
im going to mount my gauges in the glove box. im getting ones that have warning lights/buzzers built in so i dont have to have them exposed all the time, i'd just pull the glove box down on track days.
thanks for the ideas guys.
From memory, Nissan Pulsars have the same size DIN pocket with the flip down face. Go check a wrecker, you can probably pick one up for ~$10
sweet, thanks for that. ill have a look at the wreckers on the weekend.
heres how i mounted it:
it was a bit tricky trying to get my launch control switch sitting right, ill have to fabricate a mount with a decent switch so it doesnt move around, otherwise im pretty happy with it.
yeah thats the plan mate. but instead of drilling into my dash thats in perfect condition i want to mold the front of the DIN pocket in fiberglass and put a switch on it that way. i just want all the emanage stuff together in the single pocket incase i need to remove something.
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
