I'm just amazed a thread I thought was a joke is still going..
You'd be suprised, a lot of people do think it does actually help though. Only way i can see it helping is in a high horsepower application where people want to halve the amount of airflow through each filter..... no idea why though, maybe because the filter doesn't flow that much..... dont know?
But yeah, i get a few people through work asking about dual pod filter set ups.
hey M mate, just caught up on your post.
it would be useless to install 2 pods. they dont suck in any more air. because the turbo only sucks in a specific amount, although it has the surface area of the pods to work with, it cant suck in more air than it already uses.
and how would u work the afm, would u have 2 or bypass 1?
lol, did u see it done on a gtr and like it?
basically if u have a free flowing filter, and a box, WITH A CAI DUCT u will be sweet.
good luck :happy:
Edited by r33cruiser
haha yea i pretty much figured if a GTR has dual pod it must be sucking in twice the air (of course it would be cause its twin turbo) but the idea jus popped n my head about single turbo. im sure there have been other people that have thought about it tooooo ;):happy:
dude. just get a stainless steel poddie. as long as it is not smaller than the inlet on the turbo your fine.
now stop asking. light a fire under your butt
go buy one, get some mods ready for your soon to be (r34) ;):D
hey guys,
Not sure, but probably has been thought of/or done, but was thinking about getting two apexi pods and putting them on my R34 Gt-t. obviously its only a single turbo so would there be any benefit by somehow cutting a hole in the pod filter piping, joining a pipe with another pod on the end of the it so there is the dual intake? i hope u get what i mean haha let me know wat ur thoughts are.
Regards,
Mitch
The filter is a restriction; by doubling the filtration surface area and running the same airflow you'd be halving the restriction all things
being equal. If the filter posed no restriction at all, then doubling its area would make no difference - but it does. So putting dual
pods on _would_ make a difference to flow; but how much depends on how restrictive the initial situation is.
How much of a restriction is "just one"? That depends on how much airflow you're running. If
you're running stock boost you're probably not coming anywhere near the flow limits of just one filter
so adding one is probably of minimal benefit.
If you _did_ want to increase the filtration area, probably the easiest thing to do is use a bigger filter. I use a
6" diam and about 10" high K&N filter; there are all sizes in between (and no doubt, bigger ones) available...
Regards,
Saliya
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
