  • Replies 42
Posted Images
Ended up heading out and running a 11.8 @ 117mph.
Humid as night out there, saw a few skylines racing too which was good, but never really had the chance to chat to anyone.
"Ignition" DVD wanted to do an article on my car but I politely advised there's no way i'm getting in front of the video camera haha
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3447689
nice work. i saw your car there but never saw it run. My best for the night was a 11.194 @126mph. Didnt beat my 11.056@127mph from last time though. Thought i was goin to on my first run tonight as i got a goood launch with my best 60' time of 1.683 but missed 3rd gear and only ran 12.19 @109mph :D ohwel might head back friday if the weather is good
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3447833
290kw@4... it's only running stock cams / cam gears, so need to get those upgraded, which should help :rofl: Still you've got almost 60kw@4 more than me though so i'm not getting a low 11 haha... nice work!!
Nah I didn't (I heard the burnouts were starting so started packing up). Heard it hit both left and right wall? Nasty shit :D
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3447880
yeah i was lined up waiting for my last run but didnt see it happen, just heard everyone and saw everyone running. yeah from what i know after it crosed the line for an 8.6 he lost control and hit one side then across into the other.
what turbos are you running? id like to crack a 10 but i dont know if i can on the tyres im using
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3447891
congrats on the time. What kind of 60' were you doing. must of been pretty average
2.3-2.4 around there.
Still trying to get the revs and clutch work down.On the night i was dialling up 3500 and slightly dumping it.Can really ride the cushion button.
Any imput would be appreciated.
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3451977
get some MT et street radials and that will be a big help.
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3452029
Tomm0 that's a very very nice GTR you have there, noticed it in the pits as I did my usual rounds.
Thanks for the compliment :)
All photos are up too guys.
http://www.cacklingpipesphotography.com/07...treetmeet_1.htm
http://www.badgerphotography.com.au/2007/S...71031/index.htm
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3454211
off the subject, did you notice much differnce when you put in the statinless steel split dump pipe? and did the flage marry up with the exaust?
yeh i really think the tires let me down.They were some old SAVAs i had in the garage.Could hardly get smoke with a second gear burnout.
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3459448
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
