Make:Nissan
Model:R32 GTS-T
Milage:140,000km
Colour: Dark Green
RWC supplied?
Currently registered? NO
Price: $7,500.00
Contact: 0404846772
I am selling this car for a friend the current modifactions include, BOV, Exhaust System, Suspension.I do not know the full extent of modifications made to car but will be finding out this weekend along with some picture taking.
Edited by Rj34GTT
https://www.sau.com.au/forums/topic/191651-dark-green-r32-gts-t/
Compliance status?
Make:Nissan
Model:R32 GTS-T
Milage:132,000km
Colour: Dark Green
RWC supplied?
Price: $9,000.00
Contact: 0404846772
any problems with the car
As far as i know, nothing..
You can come inspect the car if you wish
Only problems are the vents in the interior of the car, which can easily be fixed. apart from that just your basic wear and tear that comes with the age of the car, but nothing too major probably just a little fade inside.
Just give me a ring if you wish to check out the car
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
