Hey there guys im new to the scene, My names Geraus... I just got my skyline R33 Series II 1996 manual im currently from the Northern Suburbs.. The power is amazing,but i think i am having idle problems.. the car is stock as a rock, like when im idle'ing in the traffic.. my engine idles funny..like its going to stall but my rev's arent moving...when doing a funny idle.. or is this normal? because of the heat.
This is my first turbo car, my 1st car was a Honda Prelude 1997 VTi-R,the skyline has much more power...
i have been researching on this fourms quite a while now and the fourm is very good and very helpful from time on i am more happy to contribute a donation to keep this fourm running as the help is very good. I am also willing to come to the SAU cruises and meet some intresting members when there on so i'l keep my heads up.
Here are the picutres of my baby.
Now i am going to mod :) I will research around. im having in mind a turbo back exhaust and a front mount.
Edited by geraus
https://www.sau.com.au/forums/topic/191688-introducing-myself/
Hi Geruas, welcome to skylines australia, i'm sure you'll enjoy your new ride. Looks really nice and clean :)
Exhaust, pod, FMIC will definitely be good mods to start off with :down:
You might want to look at the Tutorials / DIY / FAQ section where you can find really useful information down the road.
You might also want to join up with the SAU VIC club here
welcome. its good that you've actually done research before getting a skyline. much better approach than mine - buying a car when i didnt even know that there were 3 models of 'line lol.
car looks clean. and i rekon the exhaust and cooler are a good place to start.
hehe DNGRUS, i called you last week... LOL i said i was from broady n i wanted to have a look at your car.. but then i found this one :) hehehe. i asked for your address, emsta2003, i will.. at the moment now im just ordering iridium spark plugs... im having a idle issue.
Omg LIAR! lol :D so much for 'coming' on Tuesday!
Hahaa kiddin ya! Nice car, Hope u enjoy it!!
Nice bud and welcome!
Unless you like the induction/sucking noise of the pod i would bother till you're making over 230rwkw. The std airbox, with a good filter will be more than ample.
With your idle best to start with the basics.
Change plugs, gap to 0.8mm.
Maybe even pour a bottle of injector cleaner in the tank, the next time you fill up.
Does it have an aftermarket BOV?
hey and welcome. im still new hear myself and this is the best place to get info on skylines, i researched for about 6 months before i found the right one that i wanted for now. someone that kinda lives near me, well actually kinda near my work. anyway im from sunbury and work at airport west so its not to far away only like 20mins. need any questions answered this forum is definately the way to go.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
