Hey guys thanks so much for the support! CANDY33, Yeh bro ive seen ur skyline around! pwhaaaaaaaaaaaaaaaaaa thats hot... R-SPEC Thanks for the info.. I'l join the cruze to! 2 of my mates own R33's we'l be coming down to the cruzes.. :P
Yep don't bother with a pod of BOV, get yourself a cooler, full 3" exhaust and some type of boost controller (a bleed valve is cheap and reliable). After that budget for a nice ECU a Wolf or Power FC and you'll be hitting the 190-200rkw in no time :dry:
Welcome to the forums!
PS - Nice car, just like my old one :ermm:
Yep don't bother with a pod of BOV, get yourself a cooler, full 3" exhaust and some type of boost controller (a bleed valve is cheap and reliable). After that budget for a nice ECU a Wolf or Power FC and you'll be hitting the 190-200rkw in no time :(
PS - Nice car, just like my old one :dry:
add a turbo to that list then ull have the same power on an rb20 lol :ermm:
add a turbo to that list then ull have the same power on an rb20 lol :dry:
dont listen to nick man....he thinks rb20 is teh god...... :ermm:
ahah just kidding nick
enjoy the car gerus....once u have a feel for it, bring it to the track days....best fun evah!!! :(
Thanks yeh im lookin at the TRUST/GREDDY coolers.. ive just been researching on here everday.. Thanks for the help :)
I'd recommend the Blitz LM intercooler for your car, they have factory routed piping, so you don't need to go cutting a hole or your radiator fan etc.
Then a $70 GFB bleed valve on 12psi, full 3" exhaust with dump pipe, and a pod for around 200rwkw. I don't know but i found my car gained a fair amount of power using a hks pod, over the standard airbox, but for legalities sake prob stick to the standard box with a higher flowing panel filter.
Make sure you come and say hi at the GOR cruise. :w00t:
speaking of which, hows the car going!!!
Yeah really good, just had a mongoose alarm installed with key less entry. The guy came to my place and 2 hrs later hey presto beep beep buzz flash. Best $350 i ever spent.
Andrew i wish i had done that to my current car! :w00t:
got broken into a few weeks back! They stole EVERYTHING! i mean everything from clothes, to CDs, to headunit, speakers....friends belongings...:)
Really suks! Im glad to know at least u and ur car are doin well...ever since iv had mine iv been havin bad luck!
One week it gets broken into, another week i hit it, the week after that some one hits me :)
Im not driving it anymore until autosalon is over next weekend. I got it all repaired and ready again. Better stay safe till then coz at the rate my luck is goin it wil probly get ridden off or stolen!!
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
    • The pinchweld is fine, even with a trolley jack, so long as you're not actually pushing on the pinchweld itself. More to the point, we shouldn't talk about lifting or supporting on the pinchweld, we should talk about using the sill "jacking points", which just happen to be adjacent to the pinchweld. I just have dense rubber blocks with grooves in them for each of the chassis stands and the trolley jack, that I use at the sill jacking points if/when I have to lift/support there. They put all the load onto the steel pad of the jacking point and not the pinchweld. As intended.
    • Makes sense.  I would do something different if I felt like there was a better option. Generally the only other area I'm happy to jack on is where I want to put the stand. The pinch weld is not an option for me for either the jack or stands, so very limited options overall.  Plus never having had an issue with doing this, has kinda reinforced in my mind that it's fine. I'd do it on any car without a second thought these days lol.
    • I know on some cars it's explicitly endorsed in the service manual but a lot of them it isn't which is what gives me pause. I know a lot of cars also have you jack up the car by the radiator core support which is a lot easier to get to than some crazy deep section of the front subframe. I'm just reluctant to find out if any of that is really safe to do if not listed in the service manual. The FK8 has even the R-chassis beat in this regard, the front subframe jack point is almost fully behind the front tires and is surprisingly recessed into the car.
