Make: 1997 Nissan Skyline
Model: R33 SERIES 2
Milage: 89,000
Colour: Silver
RWC supplied? Can be arranged
Currently registered? Yes until september 2008
Price: $14k
Contact: David 0432380050
Comments / Modifications: 18inch RTG rims with brand new tyres 265x35x18 / 235x40x18, R34 SMIC, GTR wing, Blitz Auto Turbo Timer, Blitz BOV, HKS Superdragger Catback, Tein Coilovers
Car is in perfect condition..
Only issue with the car is the gearbox.. Its fine but to be silent requires bearings and a few synchros (can fix but will add to the cost)
Also have the original rims with basically brand new tyres..
And included is the stereo.. JVC MP3/WMA unit with USB input, speakers, amp, sub etc..
Apexi Pod filter with brace etc included as well
Has been serviced every 5000ks with Motul 8100 and timing belt / tensioner replaced at 76,000ks
Edited by MotoMan
https://www.sau.com.au/forums/topic/191724-melb-fs-97-r33-gtst-series-2/
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
