damn, was driving down the south eastern freeway on the way to work and some damn truck infront of me without covering its load flew a 1cm stone right on my windscreen.
Now my front windscreen is cracked :rolleyes::);)
Does anyone know a place in the south eastern subbie who can fix chip and crack windscreens? if so how much does it cost to fix a 1cm x 1cm crack?
Cheers All..
https://www.sau.com.au/forums/topic/19186-trucks-and-stones/
windscreen o brien does car glasses too... I found that day-to-day private glass repairmen do a good job too in patching up stuff. If you want the whole thing replaced then go to a big franchise.
https://www.sau.com.au/forums/topic/19186-trucks-and-stones/#findComment-403871
no **** u go to whittlesea glass and mirrors in epping they are the best and that guy who cuts glass is pretty sexy :)
go windscreen obriens people have said good things about them they do quick jobs at a place u choose etc.
but to see me cutting glass in my hard yakka come to whittlesea glass, we dont do windscreens but hey, im there :D
https://www.sau.com.au/forums/topic/19186-trucks-and-stones/#findComment-403896
narkeh, can you panel beating bro in law/cuz whoever take out a couple of pin dents in my fender / door?
One of my mates backed into my door, took off all the polish and left his blue paint on the car, as well as a pin dent.
https://www.sau.com.au/forums/topic/19186-trucks-and-stones/#findComment-404112
Cheers All..
Pushead... a truckie blew it's load all over you?
haha... bet that's not the first time.:shake:
https://www.sau.com.au/forums/topic/19186-trucks-and-stones/#findComment-404303
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
