fingers crossed
Good luck smelly...about time you get that thing on the road! If all other alternative dosn't work, here's my words of wisdom: do the whole blonde attitude..."oh what? i'm confused...what you mean copies...they are wheels aren't they? Whats a skyline? While i'm here, would you be able to show me where I turn on "turn on" my wind screen wiper?"... After all them question, them lost souls would deffinately feel sorry for you...
once again, good luck...tn the pimp!
https://www.sau.com.au/forums/topic/19187-fingers-crossed/#findComment-403352
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
