hi,I have just got myself a r32gts4 man.std but for 3inch ex,hks bov,k&n panel filter.want to upgrade,but have some questions,where to start?,i have Haltec interceptor,will this do the job? im guessing i/c,dump,ecu,injectors would be some of the first things to look at,so was hopeing for advice on where to start..stdRB20 5spd.cheers.$2000 to spend for now..
Edited by Jamie72
https://www.sau.com.au/forums/topic/192146-mods-for-r32gts4/
Get yourself a front mount kit from just jap they seem to work fine, a good dump pipe if you dont allready have one, chuck the rubbish k&n filter in the bin keep the airbox just put in a BMC or APEXI panel filter a good boost controller preferably Electronic and closed loop (AVCR or HKS EVC) sell the interceptor and get full management of some form (cough power fc cough) the ecu is the key to so many doors, if i had my time again i would buy that first before anything else if your a newbie spend some time and research before you buy you will also learn heaps along the way.:) hope im a help of some form
Get yourself a front mount kit from just jap they seem to work fine, a good dump pipe if you dont allready have one, chuck the rubbish k&n filter in the bin keep the airbox just put in a BMC or APEXI panel filter a good boost controller preferably Electronic and closed loop (AVCR or HKS EVC) sell the interceptor and get full management of some form (cough power fc cough) the ecu is the key to so many doors, if i had my time again i would buy that first before anything else if your a newbie spend some time and research before you buy you will also learn heaps along the way. >_< hope im a help of some form
thanks ,that should point me in the right direction,got a blitz dual sbc,should be ok?
You can end up spending alot more than you would buying a real GTR as something worth keeping in mind.
If you want something fairly mild then;
* Exhaust is a good place to start (turbo back).
* Aftermarket ecu, sort timing and fuel out prefferably or S-AFC.
* Clutch and Flywheel upgrade will be needed once power is up , a lightweight flywheel while your at it.
* You will need fuel pump and injectors once you step into an upgraded turbo
Lots of things you can do really but, depends on what you would like the car to be.
If you want lots of power in the long term, just save for a built RB26 it more or less drops straight in with very few bits to get. The GTS4 gearbox is the same strength wise too, it's not the poxy RB20 box out of gtst's.
For the record the K&N panel filters are fine and re-usable, sorry 13thracer I've used exactly the same panel filter on a high powered GTR (among other cars) with more power than the lowly RB20 is ever going to produce. People only have issues with them when they don't read instructions and over oil them.
Have a good read of some of the links here:
http://www.skylinesaustralia.com/forums/t66556.html
Specifically this one:
http://www.skylinesaustralia.com/forums/t45218.html
Goes over the basic items for you.
Cheers
thanks for the great info.happy about the gearbox,definate bonus.and that i didnt waste my 90 bucks on the k&n :rofl: i`m thinking the power fc seems like the way to go.exhaust is 3inch from turbo back,has hks voltage stabiliser,...ps.will the apexi pfc work with my blitz dual solinoid b/c ?
as you may or may not know the gts4 is a bit heavy..i think as heavy as a gtr but it has the power of a gtst. Therefore making it a bit lighter would help to
here is a thread about making a r32 gts4 lighter i started a while ago
R32 GTS4 Lighter
hope it helps :P
weight reduction is good :D:):D:) dont quote me but from memory the oldschool drag racers used to say loosing 400 pounds is equal to adding 100 HP and the best thing about weight reduction less impact on your driveline and most of it is free.
Edited by 13thracer
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
