hey ppl's
Im after a cheap 180sx.
any year any model
either a blown motor or a crashed one with not too much chassis damage.
please pm me if you have something like this
thanks
mike
https://www.sau.com.au/forums/topic/192232-wtb-cheap-180sx/
hi mate
how bout a 180/15 ?
currently in tasmania but can be bring over by boat to melbourne.
Its my mates car let me know if ur keen. Price is nego.
1991 180sx (S1580)
Body - 174,XXX
Engine - 110,XXX
SR20DET Red Top
TD05 Turbo
HKS External Wastegate
Sard 550CC Injectors
Apexi PowerFC + Hand Controller
GReddy Profec-A Electronic Boost Controller
HKS Turbo Timer
Apexi Catback Exhaust
Exedy Heavy Duty Clutch
D2 Adjustable Coilovers
Hybrid Intercooler Kit
CUSCO Brake Cylinder Stopper
17" Lightweight Buddyclub P1's
Alarm + Immobiliser + Remote Window Closure
S15 Front End Conversion
Vertex Sideskirts and Rear Bar
M-Sports Front Bar
Front + Rear Strut Braces
Sprayed in S15 Pewter Grey, Black Bonnet + Roof
Comes with the following uninstalled items
-Standard ECU
-Q45 AFM
-Brand new pod filter
-Grounding earth kit
-2 standard S13 rims+tyres
-Autometer oil pressure guage
TAS Rego Until April 2008
$16,000
pics
http://img130.imageshack.us/img130/7462/frontbar2nq4.jpg
http://img229.imageshack.us/img229/2746/car2nq3.jpg
http://img61.imageshack.us/img61/1015/s1580grassge2.jpg
https://www.sau.com.au/forums/topic/192232-wtb-cheap-180sx/#findComment-3458003
hey ppl's
any year any model
thanks
mike
When trick said the 3 key words, "CHEAP", "BLOWN", "CRASHED"
hi mate
how bout a 180/15 ?
1991 180sx (S1580)
Body - 174,XXX
Engine - 110,XXX
SR20DET Red Top
TD05 Turbo
HKS Turbo Timer
M-Sports Front Bar
-Standard ECU
-Q45 AFM
$16,000
pics
errr Uchiha, yours doesnt fit any of the 3 things he's looking for. :P
https://www.sau.com.au/forums/topic/192232-wtb-cheap-180sx/#findComment-3458567
hi mate
how bout a 180/15 ?
1991 180sx (S1580)
Body - 174,XXX
Engine - 110,XXX
SR20DET Red Top
TD05 Turbo
HKS Turbo Timer
M-Sports Front Bar
-Standard ECU
-Q45 AFM
$16,000
pics
yeah excactly what he said...
how is 16k cheap ???????
any one got a CHEAP 180sx, im talking under 5k here
cheers
https://www.sau.com.au/forums/topic/192232-wtb-cheap-180sx/#findComment-3462612
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
