Oh i spotted a silver 32 sedan in the mt gravatt area near the mexican place was a tough looking thing
he gave me the thumbs up and i gave the appreciation nod
Sounds like me :D
Your car looks mint. Mine should have tint and cr kai's soon so should look a bit better :ermm:
with SAUQLD Stickers on rear quarter windows and mesh wheels?
Didn't notice the stickers.
But I thought it was yours. I'm sure it was as well.
Wingless, mesh wheels, exactly like in the picture.
Owgasm, you usually around there Thursday nights? I'm keen for Domo Toys! I've got a Domo that sits on the rear shelf, and a little keyring size one that you usually have for phones, just dangling of the climate control temp knob lol
Not necessarily, but i'm sure we're close enough we could meet up somewhere.
Don't have anymore at this stage, i should be getting another batch in next week or the one after.
Don't want to talk up in this thread, so send me a pm and i'll let you know when i've got some.
Cheers :banana:
Silver R34 on gateway mwy this morning around 7am, PAB26? maybe. Very nice ride mate!
and a 4 door silver R34 on the way home! around 5pm maybe on the M1 southbound
Edited by Midnight Madness
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
