  • Replies 142
Posted Images
This still going Eug?
I wanna close off if possible, and dont have time to scan 7 pages to find out where its all at
Cheers
So far still going, think where at 8 people, hopefully can scrape a few more guys together other wise may as well close it off.
Cheers James
possibly down for a set. will confirm v. shortly.
what price am I looking at for a high-flow 2.5" cat? rough price on install?
you can pick up at high flow cat for approximately $100, install i wouldn't know not a hard a hard job tho.
Needs to be fabricated to....
yes, they keep a few in stock but for large orders they need to fabricate.
Cheers
this is actually an old thread from last year, we've just used this one instead of making a new one. as a lot of the older information is still quite relevant.
with the addition of 4 door love we have 7 people, another 3 more would be good and we can go ahead.
Got my extractors at work today ... nice and orange lol
Just a quick heads up to people ...
I asked for a 2.5" oulet and they sent me a set of extractors with a 2" outlet ...
dunno why or what I can do about it ? I thought they only came in 2.25 or 2.5 inch not 2 inch ... I measured up with vernier calipers and it came out to exactly 2 inch ...
currently have a 2.5" exhaust system ... might have to get the exhaust shop to cut off the rear collector and weld on a 2.5" collector ...
will have to see what the exhaust shop say if they can cut the collector off and make up a 2.5" outlet or not
Edited by hr32gts
Ahh wells ... shit happens I guess ..
I am quite impatient at times and hate waiting for stuff ... when I want something I must have it like yesterday ...
Gonna fit the extractors myself and get the exhaust shop to then cut the collector off and make up a 2.5" collector back to the standard Cat converter then to my 2.5" exhaust ...
Hopefully I notice an improvement in low to mid range performance from what others have said it is noticeable so I will wait and see ...
My mate at the exhaust shop will more than likely want to put a flex joint in where the collector normally is to help with flex of the engine so that the exhaust doesn't crack so I will see what he recommends as he has done a couple performance exhausts for me in the past and has always put a flex joint in this position...
... Hope your group buy goes well :D
P.S - The extractors are nice and Orange :P
Quick heads up for people ...
These extractors are not just a quick bolt on job ... where they weld the pipes onto the header plate the welds are too large to put the spacers on so that you can bolt them on properly ... you will either have to die grind the welds down so you can fit the shims or modify the spacers somehow ... I gave my spacers a grind but it isn't good enuf to clear the welds so I will have to pull the extractors off and die grind some of there welds away so that I can tension them up properly ...
But I did notice a bloody huge difference in engine responsiveness and more power through the mid to high end range ... gets up to speed alot smoother and pickup is much better ...
You guys will notice the difference in power that's for sure ...
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
