Item: R33 GTS-T Gearbox rebuilt with PAR Gearset.
Age: Brand New
Condition: Brand New, never run a km.
Price: $5500 The Lot. $6000 ($5500 without Clutch)
To Fit: R33 GTS-T, R32 Also?
Contact: Ben - Via PM or 0419741040
Comments: Bought the box for my car when i was doing it up, decided to sell my car before the box had even been put back in after rebuild. It was finished about a month and a half ago. All work done by TOP COG so you are free to call them and question the build or quality. Brand new Exedy Twin Plate clutch is also installed, and a C's Short Shift Kit. I've been told box is capable of 700hp or over, so would make for a great Drag setup or high tuned street car.
WILL CONSIDER TRADE WITH STANDARD BOX +CASH MY WAY
Gearbox - Brand new all built by TOP COG
- Rebuild gearbox with Cross Cut PAR Gearset
- 1st to 4th Gears
- Helical Input Gear
- Replaced 3/4 Hub / Sleeves
- Energizer Pad Spring
- NEO 75/90 Oil (Like over $200 for the oil, and i have enough left over after build for a service)
- Exedy Twin Plate Clutch w/Lightened flywheel (700HP Rating)
- C's Short Shift Kit
There was a few other little things done which i can't remember, for any further info just PM me. Thanks.
Edited by Got Boost?
  • 4 weeks later...
why you going to a standard box and trading your straight cut set???
does it have the billet selector forks and output shaft???
if you have detailed pics i will do you a change and cash you way
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
