Item: R33 GTS-T Gearbox rebuilt with PAR Gearset.
Age: Brand New
Condition: Brand New, never run a km.
Price: $5500 The Lot. $6000 ($5500 without Clutch)
To Fit: R33 GTS-T, R32 Also?
Contact: Ben - Via PM or 0419741040
Comments: Bought the box for my car when i was doing it up, decided to sell my car before the box had even been put back in after rebuild. It was finished about a month and a half ago. All work done by TOP COG so you are free to call them and question the build or quality. Brand new Exedy Twin Plate clutch is also installed, and a C's Short Shift Kit. I've been told box is capable of 700hp or over, so would make for a great Drag setup or high tuned street car.
WILL CONSIDER TRADE WITH STANDARD BOX +CASH MY WAY
Gearbox - Brand new all built by TOP COG
- Rebuild gearbox with Cross Cut PAR Gearset
- 1st to 4th Gears
- Helical Input Gear
- Replaced 3/4 Hub / Sleeves
- Energizer Pad Spring
- NEO 75/90 Oil (Like over $200 for the oil, and i have enough left over after build for a service)
- Exedy Twin Plate Clutch w/Lightened flywheel (700HP Rating)
- C's Short Shift Kit
There was a few other little things done which i can't remember, for any further info just PM me. Thanks.
Edited by Got Boost?
  • 4 weeks later...
why you going to a standard box and trading your straight cut set???
does it have the billet selector forks and output shaft???
if you have detailed pics i will do you a change and cash you way
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
