Hey ya'all
This is the third installment in the gripping series about my 33 being a slacker.
Previous post:
http://www.skylinesaustralia.com/forums/t1...45#entry3359445
My mods are now...
Turbo back 3" X-force exhaust
Cooling Pro Type 2 Front Mount - Thermal wrapped piping to manifold
Silicone Inlet Pipe
Aftermarket actuator set for ~11/12 psi
Hitachi H8 chipped ECU.
Enlarged snorkel to fit IC piping + Apexi panel filter
Front strut brace
Tomei Replacement fuel pump
S2 AFM
After sending Kubota's chip back to him, which was probably actually a great tune :teehee: I replaced the fuel pump and borrowed a S2 AFM on long term loan from Brett (BAMR33), thanks Brett! I also had a performance shop which will go unnamed adjust the ignition timing back to stock.
Today I had the guys at Auto Tech Toowoomba give her a run on the dyno and she made about 181kw, an improvement but still less than I expected. They then checked the ignition timing to discover it was 6 degrees retarded from stock...after the timing was rectified this was the dyno result.
So it was either the AFM or the fuel pump as most people had suggested.
I'm not sure which one it was as I changed both, but I suspect they were both dodgy.
I'm also presenting this as evidence that pre-tuned/chipped ECUs can get results.
Although I can only vouch for this Hitachi chipped one I bought from SECURITY, who apparently bought from MANWHORE.
Unfortunately I can not suggest where to get the socket modified ECUs, maybe somebody knows.
I do have the email address of a Sydney tuner who can pre-tune and send you a H8 chip for $250 if you can get hold of the socket modified ECU, he goes by the name of Kubota.
[email protected]
His english is a bit difficult to decipher but he's good to deal with.
As far as how the car feels to drive now, it seems to pull a bit harder at high revs, but to be honest it still feels slack off the mark, even though the boost peaks at 12psi quickly.
Comments are welcome!
Edited by vault13
https://www.sau.com.au/forums/topic/192411-33-low-dyno-power-solved/
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
