Hi guys,
The time has come to part with my passion....
I changed jobs at the start of the year and lost my company car.
The job I am doing now requires me to do a far bit of driving and some times with customers.
So unfortunatly I can not afford to buy a second car so the only option is to sell...
The car is in great condition, engine fully built and making good power.
My first tune that I did was very mild and now probly due to crank it up a bit.
At 1.2 bar with little timming the car made 450HP. The cams need adjusting and a little more time on a tune and this combo will easy make 400 rwKw (520-530 Hp)
This is a very regretful sale and the price will not move much.
I will post some picture sortly and a dyno sheet. The car is very responsive!!!
Performance
Full engine rebuild less than 6,000 Km’s (January)
2860r-5’s Garret turbo's with S/S manifolds
R34 Rb26 Crank
N1 oil pump
Eagle H beam rods
AP rod bolts
CP Pistons 86.5mm Bore
Tommi rod and main bearings
Head fully rebuilt
Tommi oil restrictor
ACL race series Metal head gasket
Full Nissan gasket set
Full match ported head
R33 RB26dett Block
HKS oil filter relocation kit
HKS oil cooler
Tommi pon cams type B
Tommi adjustable cam gears
Sard 700 cc injectors
Trust sump ex-tension and baffle kit
G-reddy twin BOV’s
Apexi air intakes
RB20 air flow meters
Nismo oil separator
G-reddy radiator
G-reddy high pressure cap
16” Thermo fan
Jasma 3.5" exhaust
Custom 3” dump pipes
N1 water pump
Nissan Timing belt
Fuel pump – Bosch 044 in tank with power up-grade
HKS triple plate clutch 80%+
Battery re-location to boot
Hi-cas removed – Lock bar fitted
Custom intake piping (3”)
N1 oil pump
Electrics
Apexi power FC
Apexi hand control
Apexi AVCR
HKS turbo timer
Pro Comp oil Gauge
Exterior
17” Volk GTP rims with 90% tread (255/40/R17)
Falken front lip
Tein coil overs
Brembo brakes (front- Project MU pads)
Apexi front two piece rotors
Interior
Alpine deck & 12 disc stacker,
320km dash
Key less entry (immobilizer)
No time for people wanting to go for a thrash...
Price $26,500 ono
Contact me VIA PM or 0437518009
I am in Canningvale area of Perth WA
post-12745-1194346819_thumb.jpgpost-12745-1194346853_thumb.jpgpost-12745-1194434944_thumb.jpgpost-12745-1194434986_thumb.jpgpost-12745-1194435055_thumb.jpg[attachment
128105:DSC_0386.JPG]post-12745-1194435138_thumb.jpgpost-12745-1194435183_thumb.jpgpost-12745-1194435224_thumb.jpgpost-12745-1194435251_thumb.jpg
Edited by seeyagtr
Hi,
I built the engine my self, I have done 4 full engine rebuild on gtrs (Rb26dett and rb26det) engines now the they are all making 350-400 rwkw with simular builds. (Contacts/Reference's advilable if required)
The tune has been done by Top Racing. I will post the dyno Sheet today. (Have to get hold of a scanner)
Cheers
This thing is clean as guys. Used this in my wedding. One of the cleanest GTR's out there. Painstakingly looked after.
Goes hard, sounds hot and looks amazing.
IMO a absolute bargain!!
Good luck dude.
Hi Guys.
Shame to see Rory selling his beast. Has had it for 4 years, Always garaged, always clean, always serviced every 5000km.
He helped me build my RB26det, that will tune for 400+rwkw.
This car goes, stops and turns every time.
Would be a steal at this price.
cms
This is an absolute f**king bargain, good luck with the sale mate!!!
Most stockish GTR's go for 20-23k... (in decent condition)... so a fully built motor for $3k more? You can't even buy the turbos alone for that price! :whistling:
Good luck,
Christian
HI guys,
This car is still for sale, the car is in great condition with the power to match!!!
Also posted in the WA for sale section!
sent pm
Edited by Marko R1
How is the dyno sheet coming?
Also, how wide are the wheels?
HI,
Thanks for the heads up on the dyno sheet,
This tune is what the car is running now, if you want the car for top end power the inlet cam needs to be retarded 2-4 degress and the exhust 2 degress.
With the cams timming now I have gained mid range torque and get the turbos to spool on quickly.
The car reachs full boost at 3800 to 4000 rpm. The car normal runs waste gate pressure at 0.9 bar.
The car has 17 X 9 1/2 rims with 255/45 R17 tyres.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
