Item: RB30DET
Condition: Never used since rebuild
Price: $4500obo
Contact: PM or leave post
Comments:
I imported this new from RIPS (http://www.ripsltd.co.nz/performance/products.html) a while ago for my datsun but have changed project direction.
As you can see, their STD internal long motors now sell for $4750NZD (The same as this one which RIPS have acheived up to 600hp).
Also included is a RIPS front facing plenum ($1200NZD).
The head is an R32 RB25DE and comes with matching loom and ECU (although full aftermarket ECU recommended).
Also includes new HD clutch.
For $5000 I will throw in a brand new XR6 turbo fitted to the motor with braided oil line & fittings.
I can deliver for free anywhere within Melbourne, not really interested in organising interstate freight, but buyers can do so if they wish.
Edited by drunkenmaster
https://www.sau.com.au/forums/topic/192466-fs-rb30det/
  • 1 month later...
if ur interested in seperating im interested in the intake plenum. if u are willing to seperate just give me a ruff idea of how much u want for the inlet manifold, cheers
I'd only seperate if I had other buyers for the remainder.
Will consider all offers.
https://www.sau.com.au/forums/topic/192466-fs-rb30det/#findComment-3521672
if this motor is sold with out manifolds ect im still keen on the intake manifold, is there a difference between rb25det and rb25de intake manifold bolt patterns?
Deposit has been taken on the full package guys.
For reference, there is a difference in inlet port size between RB25DE and other RB motors. Therefore it is quite difficult to get an aftermarket plenum to suit the RB25DE style RB30DET motors.
https://www.sau.com.au/forums/topic/192466-fs-rb30det/#findComment-3550076
yeh after some research i found this out. Main way to go is with teh 25DE runners with the 20 plenum. Not that hard but...Good luck with it all mate.
Yep, I have a spare set of runners (complete RB25DE manifold) which i may sell soon.
Was bloody hard to find a set someone was willing to seperate from the head.
As far as I know the actual upper plenums are the same between RB20DET/25DE.
https://www.sau.com.au/forums/topic/192466-fs-rb30det/#findComment-3550286
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
